Recommendation for Autocad programming approach
Hi, I'm an experienced C# programmer but have no experience in Autocad. I'm assigned a job to develop a C# program to automate 2D drawing on mechanical parts on Autocad 2010.
I've downloaded the ObjectArx SDK and went through a simple tutorial using the NETLOAD to get the program to run in Autocad.
Also, as I'm not familiar with Autocad, I thought I might need to understand how the 2D drawing is done. -> what are the properties or how the entities/objects relate to each other. I might need to use vector or trigonemetry to draw based on some inputs. Is there anyone who is experienced in this area who can give some advice on how I should approach this?
I'm gone through tutorials online that show how a designer use Autocad, but are there any resource that gives a programmer point of view? The closest book that I found is VB.Net for Autocad 2010 -> is this good? Are there any C# books or other books that I should look at?
 I'm a little overwhelmed 🙂
Thanks!
michael_robertson
If you are drawing things, geometry is definitely going to come into play in a big way. Almost everything will be based off of points (where lines start/stop, center of arcs, etc).
The best advice I can give you is to sit down with a Cad Technician or Engineer that currently does this process manually and get a feel for what they are doing, then abstract it out so you can automate it.
The blog http://through-the-interface.typepad.com/through_the_interface/ by Kean Walmsley is a good reference as it this Discussion Group.
The VB.Net for Autocad 2010 is a pretty good book to get the basic ideas and processes covered (and easy enough to convert to C#).
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Hallex
Take a look at this page as well
http://docs.autodesk.com/ACD/2010/ENU/AutoCAD%20.NET%20Developer's%20Guide/index.html?url=WS1a919382...
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Thanks, Michael and Hallex for the suggestions.
I will look into the online documentation as well.
Cheers.
