Reading/writing to .dwg files without AutoCAD?
Is this possible?  I was trying to make a simple windows program that prompted the user to select a .dwg file and the program would list all the layers in a listbox.  But the Database.ReadDWGFile procedure doesn't appear to work outside of AutoCAD (FileNotFound Exception).  Can I have my windows program open AutoCAD in the background to achieve this?
Here's my code:
Imports Autodesk.AutoCAD.Runtime
Imports Autodesk.AutoCAD.ApplicationServices
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.EditorInput
Public Class Form1
    Dim myLayers As ArrayList
    Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click
        Dim myDB As New Database(False, True)
        myDB.ReadDwgFile("C:\test.dwg", FileOpenMode.OpenForReadAndAllShare, True, "")
        Using myTrans As Transaction = myDB.TransactionManager.StartTransaction
            Dim myLayerTable As LayerTable = myDB.LayerTableId.GetObject(OpenMode.ForRead)
            Dim layerName As String = ""
            For Each myObjectID As ObjectId In myLayerTable
                Dim myLayer As LayerTableRecord = myObjectID.GetObject(OpenMode.ForRead)
                myLayers.Add(myLayer.Name)
            Next
            myTrans.Abort()
        End Using
        myDB.Dispose()
        For Each layerxx In myLayers
            ListBox1.Items.Add(layerxx)
        Next
    End Sub
End Class
Is this possible?
No.
Yes.
You can only use ActiveX interface of AutoCAD from external application, e.g.
Autodesk.Autocad.Interop and
Autodesk.Autocad.Interop.Common
arcticad
You can use either AutoDesk  RealDWG
http://usa.autodesk.com/adsk/servlet/index?siteID=123112&id=770257
or Teigha™.NET for .dwg files
http://www.opendesign.com/
To modify files without Autocad.
These are both pay options.
The only free options is to have Autocad Installed and use ActiveX.
(defun botsbuildbots() (botsbuildbots))
Sweet.  Many thanks to both of you.
