02:02 PM
Here is some code:
Private Sub ObjectModified(ByVal sender AsObject, ByVal e As Autodesk.AutoCAD.DatabaseServices.ObjectEventArgs)
With e.DBObject
If .IsWriteEnabled Then Exit Sub
If .Id.ObjectClass.Name = "AcDbAttribute"Then
End With
End Sub
Trying to read the attribute's tag and text.
Can't work out what goes in ????
or do I need to get the Blockreference and work through each attribute?
I promise I will start repaying your help soon.
