Read Lisp's property by VB.NET
Message 1 of 9
Hi
I have old Lisp macros, that writes property to drawing by command (vlax-ldata-put "SpData" cVar cVal). How can I read this property's value, using VB.NET ?
I attached file with this property, its value="TEST"
Replies (8)
Message 2 of 9
Hallex
See if this is working for you:
    Public Function GetDictionary(ByVal dictname As String) As DBDictionary
        Dim dict As New DBDictionary
        Dim db As Database = HostApplicationServices.WorkingDatabase
        Using tr As Transaction = db.TransactionManager.StartOpenCloseTransaction
            Dim nod As DBDictionary = TryCast(tr.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead), DBDictionary)
            If nod Is Nothing Then
                Return Nothing
            Dim id As ObjectId = ObjectId.Null
            Try
                id = nod.GetAt(dictname)
                dict = TryCast(tr.GetObject(id, OpenMode.ForRead), DBDictionary)
                If dict Is Nothing Then
                    Return Nothing
                Else
                    Return dict
            Catch ex As Exception
                Return Nothing
            End Try
        End Using
    End Function
    <CommandMethod("ldt")> _
    Public Sub GetLdata()
        Dim doc As Document = Application.DocumentManager.MdiActiveDocument
        Dim ed As Editor = doc.Editor
        Dim db As Database = doc.Database
        Dim spdict As DBDictionary = Getdictionary("SpData")
        If spdict IsNot Nothing Then
            MsgBox("""SpData"" dictionary exist")
        Else
            MsgBox("""SpData"" dictionary does not exist")
            Return
        For Each de As DictionaryEntry In spdict
            ed.WriteMessage("\n{0}\t{1}", de.Key, de.Value)
        Next
    End Sub
    'I've got the returned values like this:
    '    \nFileName\t(2129675160)\nFUSAGE\t(2129675096)\nNAIM\t(2129675088)\nNCONTR\t(212
    '9675128)\nOBOZN\t(2129675080)\nPOSDELTA1\t(2129675144)\nPOSDELTA2\t(2129675152)\
    'nPROV\t(2129675112)\nQUANTNUM\t(2129675168)\nRAZRAB\t(2129675104)\nTCONTR\t(2129
    '675120)\nUTV\t(2129675136)
~'J'~
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Message 3 of 9
Thank You!
I so understood that de.Value is an Autodesk.Autocad.DatabaseServices.ImpDBObject's ID? How to get this object's text? I tried do this, but got error "Autodesk.AutoCAD.DatabaseServices.ImpDBObject is unavailable in this context because it's 'Friend' ".
    Using tr As Transaction = db.TransactionManager.StartTransaction
      Dim imp As Autodesk.AutoCAD.DatabaseServices.ImpDBObject = tr.GetObject(de.Value, OpenMode.ForWrite, False, True)
      MsgBox(imp.Text)
     End Using
Next
Message 4 of 9
Hallex
Try to use OpenMode.ForRead instead:
          Dim imp As Autodesk.AutoCAD.DatabaseServices.ImpDBObject = tr.GetObject(de.Value, OpenMode.ForRead, False, True)
        MsgBox(imp.Text)
Next
  End Using
If you do open for write, you have first open for write "SpData" dictionary,
then digg deeper inside
Message 5 of 9
if I made so, I received an error:
'Here I got error: "Autodesk.AutoCAD.DatabaseServices.ImpDBObject is 'unavailable in this context because it's 'Friend' "
 Trying to made so:
Dim obj As DBObject = tr.GetObject(de.Value, OpenMode.ForRead, False, True)
MsgBox(obj.Handle.Value.ToString)
 but received numbers like 440 ... 435 ... etc
This construction:
MsgBox(obj.Handle.ToString)
 Returns 1BB ... 1B3 ... etc, but not text string "Test", like in file
Make this:
      Dim txt As DBText = obj
      MsgBox(txt.TextString)
  Next
End Using
 But received error "it was not possible to give object type  Autodesk.AutoCAD.DatabaseServices.ImpDBObject to  Autodesk.AutoCAD.DatabaseServices.DBText" (sorry, I translate errors from non-english version of Visual Studio)
I in perplexity Smiley Indifferent
Message 6 of 9
DiningPhilosopher
Well, using vlax-ldata-* functions is a grave mistake to start with, going by the fact that in one AutoCAD release, Autodesk provided no way to access data that was put there by a previous release.
I would suggest you get your data out of that 'trap' and use XRecords instead, because they don't have that problem, and you can get at them from any API.
In the mean time, the only way to get this data from managed code is by P/Invoking acdbEntGet().
"ImpDBObject" is the managed wrapper type that AutoCAD places around database objects that have no other specific managed wrapper type (IOW, object types that are not supported by the managed API). And because there's no specific managed wrapper provided for the custom object that stores the data accessed via vlax-ldata-* functions, it gets this wrapper by default.
You can search this forum for more information on using acdbEntGet() from managed code.
Message 7 of 9
DinigPhilosopfer, thanks, I will try
Message 8 of 9
viper_007
I'm confused by vlax-ldata-*, too.
Thank you, maybe I can have the problem solved.
聚傲气于一身,显傲骨之精华
Message 9 of 9
Balaji_Ram
Here is another approach to retrieve the data &colon;
http://adndevblog.typepad.com/autocad/2013/01/accessing-ldata-values-from-vba.html
Balaji
Balaji
Developer Technical Services
Autodesk Developer Network
