read from xref
read from xref
read from xref
I've written some code voor C3D R2010 and all has worked fine without errors. In C3D R2013 I get numerous errors.
Now I have an error when I want to read info from an x-reffed file.
When executing the code db.ReadDwgFile(tekening, IO.FileShare.Read, True, "")
Autocad gives a Fatal Error
See code
hlp = "C:\magweg\8859 4a GRONDPLAN CIVIL.dwg"
if zoekkaders (hlp) then ...
    Public Function zoekkaders(ByVal tekening As String) As Boolean
        Dim myDWG As ApplicationServices.Document
        Dim myEd As EditorInput.Editor
        Dim myBlock As DatabaseServices.BlockReference
        myDWG = ApplicationServices.Application.DocumentManager.MdiActiveDocument
        myEd = myDWG.Editor
        Dim db As New DatabaseServices.Database
        If tekening <> "basis" Then db.ReadDwgFile(tekening, IO.FileShare.Read, True, "") Else db = myDWG.Database
Balaji_Ram
I suggest asking this question in the Discussion group for Civil3d Customization.
http://forums.autodesk.com/t5/AutoCAD-Civil-3D-Customization/bd-p/190
I am sure you will get an answer there.
Balaji
Developer Technical Services
Autodesk Developer Network
