Publishing a Sheet Set using VB.Net
Hi Everyone!
I am trying to create a custom publish to plotter script using VB.Net. I'm have a very limited knowledge in VB.Net Programming and I'm trying to learn the basics. I would like to ask if someone here have created a custom script that performs the same function as the built-in Publish to Plotter command in the Sheet Set Manager of AutoCAD 2015? The requirements that I need for the code is as shown:
1. Loop thru the sheet set
2. Print each drawing layout found in the sheet set using a custom page layout.
3. Save in a specified folder.
Basically, the code acts similar as the Publish to Plotter command wherein it publishes the drawing layout individually (multiple sheets) rather than a single sheet PDF.
I want to create this custom script since the Publish to Plotter or the Publish using Dialog Box outputs the drawing a bit blurred since the override uses the default DWG to PDF.pc3. The custom plotter that I will use is the Adobe PDF.pc3 but this can't be used as override for publishing.
I searched all over the internet and also asked our local Autodesk support in my country and no one was able to help me 🙂 I'm looking forward to anyone's help.
Thanks!
Jeremiah
The key of what you want to do is working with Application.Publisher object, its PublishExecute() method and the DsdData object you need to pass to it.
I couldn't retrieve the original post from where I started, but I remember was posted in Autodesk's DevBlog...
So far I could only find this link to Kean's blog, that can also be a start: http://through-the-interface.typepad.com/through_the_interface/2007/09/driving-a-multi.html
Anyway, I'm also posting my code, that has been thought mostly to print multiple files, with multiple layouts, into a single PDF file.
The list of files can be retrieved from your SheetSet, and you can change the plot configuration to print to single files instead of a multipage PDF.
Also, I never tried other drivers, so I cannot say if it works with Adobe driver...
Just my cent:
static public void BatchPublishCmd(List<String> docsToPlot, String szOutputFile)
    short bgPlot = (short)Application.GetSystemVariable("BACKGROUNDPLOT");
    Application.SetSystemVariable("BACKGROUNDPLOT", 0);
    // retrieve plot configuration from project settings
    string szPlotterName = csSettings.plt_Plotter;
    string szStyle = csSettings.plt_Stile;
    string szMedia = csSettings.plt_Formato;
    string szScala = csSettings.plt_Scala;
    bool bCentrapagina = csSettings.plt_bCentraPagina;
    if (szMedia.ToLower().StartsWith("auto")) szMedia = "";         // if not specified, allow for automatic selection of media
    StdScaleType eScale = ConvertScaleToType(szScala);
    DsdEntryCollection collection = new DsdEntryCollection();
    foreach (String filename in docsToPlot)
        // read file without loading in graphics window
        Database db = new Database(false, true);
        db.ReadDwgFile(filename, FileShare.ReadWrite, true, "");
        string docName = Path.GetFileNameWithoutExtension(filename);
        using (Transaction Tx = db.TransactionManager.StartTransaction())
             ObjectIdCollection layoutIds = GetLayoutIds(db);
             foreach (ObjectId layoutId in layoutIds)
                 Layout lo = Tx.GetObject(layoutId, OpenMode.ForWrite) as Layout;
                 Point3d pMin = lo.Extents.MinPoint;
                 Point3d pMax = lo.Extents.MaxPoint;
                 PlotSettingsValidator psv = PlotSettingsValidator.Current;
                 PlotSettings ps = new PlotSettings(lo.ModelType);
                 ps.CopyFrom(lo);
                 // assegna stile di stampa, se presente
                  _SetPlotStyle(szStyle, ps, psv);
                 ps.ScaleLineweights = false;
                 psv.SetPlotType(ps, Autodesk.AutoCAD.DatabaseServices.PlotType.Extents);
                 psv.SetUseStandardScale(ps, true);
                 psv.SetStdScaleType(ps, eScale);
                 psv.SetPlotCentered(ps, bCentrapagina);
                 //psv.SetPlotPaperUnits(ps, PlotPaperUnit.Millimeters);
                 bool bPaperIsLandscape;
                 bool bAreaIsLandscape;
                 if (lo.ModelType) bAreaIsLandscape = (db.Extmax.X - db.Extmin.X) > (db.Extmax.Y - db.Extmin.Y) ? true : false;
                 else bAreaIsLandscape = (lo.Extents.MaxPoint.X - lo.Extents.MinPoint.X) > (lo.Extents.MaxPoint.Y - lo.Extents.MinPoint.Y) ? true : false;
                 // find best media
                 szMedia = _PlotSetMedia(szPlotterName, szMedia, lo, ps, psv);
                 // find best rotation
                 bPaperIsLandscape = (ps.PlotPaperSize.X > ps.PlotPaperSize.Y) ? true : false;
                 if (bPaperIsLandscape != bAreaIsLandscape) psv.SetPlotRotation(ps, PlotRotation.Degrees270);
                 // save plot info back to layout, will be needed later when publishing
                 ps.PlotSettingsName = lo.LayoutName + "_plot";
                 ps.PrintLineweights = true;
                 ps.AddToPlotSettingsDictionary(db);
                 Tx.AddNewlyCreatedDBObject(ps, true);
                 psv.RefreshLists(ps);
                 lo.CopyFrom(ps);
                 // write info for publishing list
                 DsdEntry entry = new DsdEntry();
                 entry.DwgName = filename;
                 entry.Layout = lo.LayoutName;
                 entry.Title = docName + "_" + lo.LayoutName;
                 entry.NpsSourceDwg = entry.DwgName;
                 entry.Nps = ps.PlotSettingsName;
                 collection.Add(entry);
             Tx.Commit();
        db.RetainOriginalThumbnailBitmap = true;
        db.SaveAs(filename, true, DwgVersion.Current, db.SecurityParameters);
    DsdData dsd = new DsdData();
    dsd.SheetType = (szPlotterName.ToUpperInvariant().Contains("PDF") ? SheetType.MultiPdf : SheetType.MultiDwf);
    dsd.ProjectPath = csSettings.m_szTempFolder;
    dsd.DestinationName = szOutputFile;
    dsd.IsHomogeneous = false;
    if (File.Exists(dsd.DestinationName)) File.Delete(dsd.DestinationName);
    dsd.SetDsdEntryCollection(collection);
     string dsdFile = csSettings.m_szTempFolder + "\\dsdData.dsd";
     if (File.Exists(dsdFile)) File.Delete(dsdFile);
     //Workaround to avoid promp for dwf file name
     //set PromptForDwfName=FALSE in dsdData
     //using StreamReader/StreamWriter
     dsd.WriteDsd(dsdFile);
     StreamReader sr = new StreamReader(dsdFile);
     string str = sr.ReadToEnd();
     sr.Close();
     str = str.Replace("PromptForDwfName=TRUE", "PromptForDwfName=FALSE");
     str = str.Replace("PromptForPdfName=TRUE", "PromptForPdfName=FALSE");
     System.IO.StreamWriter sw = new System.IO.StreamWriter(dsdFile);
     sw.Write(str);
     sw.Close();
     dsd.ReadDsd(dsdFile);
     PlotConfig plotConfig = PlotConfigManager.SetCurrentConfig(szPlotterName);
     Publisher publisher = Application.Publisher;
     publisher.PublishExecute(dsd, plotConfig);
     //reset the background plot value
     Application.SetSystemVariable("BACKGROUNDPLOT", bgPlot);
private static ObjectIdCollection GetLayoutIds(Database db)
    ObjectIdCollection layoutIds = new ObjectIdCollection();
         DBDictionary layoutDic = Tx.GetObject(db.LayoutDictionaryId, OpenMode.ForRead, false) as DBDictionary;
         foreach (DBDictionaryEntry entry in layoutDic)
             Layout lay = (Layout)Tx.GetObject(entry.Value, OpenMode.ForRead);
             if (lay.ModelType) continue;
             // check for empty layouts, to be ignored
             BlockTableRecord btr = (BlockTableRecord)Tx.GetObject(lay.BlockTableRecordId, OpenMode.ForRead);
              // count entities in layout, keep only if there is more than 2 entities
              int count = 0;
              foreach (ObjectId o in btr)
                  if (++count > 2) break;
              if (count > 2) layoutIds.Add(entry.Value);
        // if there are no valid layout, add modelspace as Layout object
        if (layoutIds.Count == 0)
                if (lay.ModelType)
    return layoutIds;
private static void _SetPlotStyle(String szStyle, PlotSettings ps, PlotSettingsValidator psv)
    if (szStyle.Length > 0)
        System.Collections.Specialized.StringCollection sc = psv.GetPlotStyleSheetList();
        foreach (String szStyleFullName in sc)
            if (System.IO.Path.GetFileName(szStyleFullName) == szStyle)
                psv.SetCurrentStyleSheet(ps, szStyleFullName);
                break;
private static String _PlotSetMedia(String szPlotterName, String szMedia, Layout lo, PlotSettings ps, PlotSettingsValidator psv)
    if (szMedia.Length > 0)
        // set current plotter
        psv.SetPlotConfigurationName(ps, szPlotterName, null);
        System.Collections.Specialized.StringCollection v = psv.GetCanonicalMediaNameList(ps);
        String szCanonicalName = "", szTmp;
        // find media by canonical name
        foreach (String s in v)
            if (s == szMedia)
                 szCanonicalName = szMedia;
                 break;
            else
                // check local name, if applicable
                szTmp = psv.GetLocaleMediaName(ps, s);
                if (szTmp == szMedia)
                    szCanonicalName = s;
                    break;
        psv.SetPlotConfigurationName(ps, szPlotterName, szCanonicalName);
        psv.SetPlotRotation(ps, PlotRotation.Degrees000);
    else
        // media not selected, choose the best from plot size (choose your strategy here)
        if (lo.ModelType) szMedia = FindBestFormat(ps, psv, szPlotterName, lo.Database.Extmin, lo.Database.Extmax);
        else szMedia = FindBestFormat(ps, psv, szPlotterName, lo.Extents.MinPoint, lo.Extents.MaxPoint);
    return szMedia;
Thanks @Anonymous! I'll try your code by tweaking the values that I need and give you my feedback 🙂
In AutoCAD there is options to set vector quality, bookmarks, layer information, etc... How do we set all this pragmatically?
