promptselectionresult with change-able keywords
stefanveurink68AXD
Message 1 of 19
stefanveurink68AXD
Hey, I want to get a selection from user, while giving the possibility to change certain 'variables' for the code.
With promptentityoptions i do this (simplified) like:
string S_Scale = "Scale=1:" + D_Scale;
PromptEntityOptions opt = new PromptEntityOptions("\nSelect");
opt.Keywords.Add(S_Scale);
 PromptEntityResult res = ed.GetEntity(opt);
 if (res.Status == PromptStatus.OK)
 else if (res.Status == PromptStatus.Keyword)
    if (res.StringResult == S_Scale)
       PromptStringOptions pso = new PromptStringOptions("\nScale 1 op:");
       PromptResult res1 = ed.GetString(pso);
      DPSchaal = Convert.ToDouble(res1.StringResult)
However, with promptselectionoptions, I don't seem to get into the "prompstatus.keyword when clicking/entering the keyword. Tried it these ways:
https://www.keanw.com/2010/05/adding-keyword-handling-to-autocad-nets-getselection.html
https://help.autodesk.com/view/OARX/2024/ENU/?guid=GUID-94A4E3DE-0066-4D6A-8558-0252BE8CB85E
but these don't seem to work either.
Is it possible to do what I want, or isn't this available? And if yes, how?
Replies (18)
Message 2 of 19
Jeff_M
@stefanveurink68AXD Show the code you tried based on Kean's example. It should work, as that is the way all of my selections with Keywords are handled.
Jeff_M, also a frequent Swamper
Message 3 of 19
stefanveurink68AXD
double Puntafstand = 0.5;
var PSopties = new PromptSelectionOptions();
string S_puntafstand = "MaxAfstand=" + Puntafstand.ToString();
PSopties.Keywords.Add(S_puntafstand);
string kws = PSopties.Keywords.GetDisplayString(true);
PSopties.MessageForAdding = "selecteer de punten en lijnen" + kws ;
PSopties.KeywordInput += delegate (object sender, SelectionTextInputEventArgs e)
               string key = e.Input;
                if (key == S_puntafstand)
                    PromptStringOptions pso = new PromptStringOptions("\nGeef maximale afstand:");
                    pso.AllowSpaces = false;
                    PromptResult res1 = edi.GetString(pso);
                    bool inputakkoord = true;
                    try
                        Puntafstand = Convert.ToDouble(res1.StringResult);
                    catch
                        inputakkoord = false;
                    if (inputakkoord == false)
                        MessageBox.Show("Dit is geen getal!");
See above, I see the keyword, but it doesn't seem to get into the 'delegate code', I can't reach the 'string key = e.input" in my debugger.
Message 4 of 19
Jeff_M
@stefanveurink68AXD you are confusing different selection types. GetEntity does not utilize the PromptSelectionOptions. Going back to the original code you posted, something like this is more of what you will be needing.
        [CommandMethod("LetsTestThis")]
        public void letstestthis()
            var D_Scale = 1.0;
            var DPSchaal = double.NaN;
            var doc = Application.DocumentManager.MdiActiveDocument;
            var ed = doc.Editor;
            string S_Scale = "Scale=1:" + D_Scale.ToString("F0"); ;
            opt.AppendKeywordsToMessage = true;
            while (res.Status == PromptStatus.Keyword)
                    PromptDoubleOptions pso = new PromptDoubleOptions("\nScale 1 op:");
                    var res1 = ed.GetDouble(pso);
                    DPSchaal = res1.Value;
                    S_Scale = "Scale=1:" + res1.Value.ToString("F0");
                    opt.Keywords.Clear();
            if (res.Status != PromptStatus.OK)
                return;
Message 5 of 19
stefanveurink68AXD
Yes I understand that it works with getEntity, but then I can only select one entity. I want to select multiple, including filtering. If I understand you correct you say this is not possible? Didn't expect it to be such a difference.
Message 6 of 19
ActivistInvestor
Try testing your code with a relatively- simple test keyword rather than the one that you are using (that contains an equals sign). And, make sure that the keyword doesn't conflict with any of the keywords that are available at the select objects prompt. And see if that keyword works and if your Handler is being entered with it.
Message 7 of 19
stefanveurink68AXD
Okay, got it kinda working now (including the "="-sign, also tried it without).
Only thing is I can't get the keywords to change dynamically. Like with the PromptEntityOptions.
private SelectionSet bochten(string message)
            string S_Tol = D_tolerance.ToString();
            string S_Tolerance = "Tolerance=" + S_Tol;
            PSopties.Keywords.Add(S_Tolerance)
            PSopties.MessageForAdding = "Do selection or: " + kws;
                if (key == S_tolerance)
                PromptStringOptions pso = new PromptStringOptions("\n set tolerance: ");
                    try
                        double b = Convert.ToDouble(res1.StringResult);
                        D_tolerance = b;
                        PSopties.Keywords.Clear();
                        PSopties.Keywords.Add(S_Tolerantie);
                    catch
                        MessageBox.Show("input error");
Tried different options. The keyword is changed, because when i break out of it (by pressing "esc" in autocad) and start it again, the keyword is updated.
But I can't get it working to break out of it within the code after changing the keyword. This would be not perfect, but acceptable.
Most perfect would be the keyword changing while still in the same loop.
Any ideas?
Message 8 of 19
ActivistInvestor
Any ideas?
I don't see any loop in the code you show above. If that code is being executed within a loop at an outer scope that's not shown, there is a new PromptSelectionOptions instance created on each loop iteration, and would explain why the keyword isn't changing on each prompt.
If you're calling GetSelection() in a loop, you have the pass the same instance of the PromptSelectionOptions on each iteration, rather than creating a instance on each iteration.
Message 9 of 19
stefanveurink68AXD
yeah sorry 'loop' was not the right word used, there is no loop. I meant to say 'command'.
Message 10 of 19
ActivistInvestor
After looking at your code again the problem is that when the user responds with a keyword, the call to GetSelection() returns. That means there must be a loop that calls GetSelection() on each iteration.
Message 11 of 19
stefanveurink68AXD
Yes okay, I see what you mean, but problem is, in contrary to SelectEntity, i have to put the delegate before the GetSelection, so you never enter the 'else' part other then from breaking out of the 'command'.
  while(true)
            //you only reach this place one time, not looping.
                    try
                        D_tolerance = b;
                    catch
                PromptSelectionResult res = edi.GetSelection(PSopties, filter);
                    SelectionSet set = res.Value;
                    return set;
                else
Message 12 of 19
ActivistInvestor
After looking at the disassembled code for GetSelection() it doesn't appear that there is any way to change the keywords after GetSelection() is called. The keyword event handler is called from native code, and that code will continue to issue prompts for selection as long as a keyword is entered.
Also, what I wrote above is not true. GetSelection() doesn't return when you enter a keyword, it calls the keyword event handler and then reissues the prompt for input, and the keywords cannot be changed. The only way to exit the call to GetSelection() is to supply another type of response (select objects, or cancel/esc).  I would call that a deficiency in the design as changing keywords and optionally exiting the internal loop are legitimate requirements in certain use cases.
The only way I can find to exit the call to GetSelection() when a Keyword is entered, is to throw an exception from the keyword input event handler, and catch it in the code that calls GetSelection().
Here's an example:
public static class PromptSelectionWithKeyword
   public static PromptSelectionResult GetSelectionWithKeywords(this Editor editor, params string[] keywords)
      string keyword = null;
      int i = 0;
      PromptSelectionOptions pso = new PromptSelectionOptions();
      pso.KeywordInput += OnKeywordInput;
      foreach(string s in keywords)
         pso.Keywords.Add(s);
      pso.Keywords.Add("Quit");
      pso.Keywords.Add("Change");
      void OnKeywordInput(object sender, SelectionTextInputEventArgs e)
         keyword = e.Input;
         if(e.Input == "Quit" || e.Input == "Change")
            throw new KeywordException(e.Input); // break out of loop
         // Otherwise, prompt is repeated with the same keywords.
      PromptSelectionResult result = null;
      while(true)
         try
            result = editor.GetSelection(pso);
         catch(KeywordException ex)
            editor.WriteMessage($"\nKeyword input: {ex.Keyword}");
            if(ex.Keyword == "Quit")
               return null; // Can't return PromptSelectionResult
            else if(ex.Keyword == "Change")
               /// Modify/add/remove keywords here
               pso.Keywords.Add("NewKeyword");
            continue;
         return result;
   public class KeywordException : System.Exception
      string keyword;
      public KeywordException(string keyword)
         this.keyword = keyword;
      public string Keyword => keyword;
   [CommandMethod("SELECTWITHKEYWORDS")]
   public static void Test()
      Document doc = Application.DocumentManager.MdiActiveDocument;
      Editor editor = doc.Editor;
      var psr = editor.GetSelectionWithKeywords("FIrst", "Second", "Third");
      if(psr == null)
         editor.WriteMessage("\nUser chose Quit");
      else
         editor.WriteMessage($"\nresult.Status = {psr.Status}");
Message 13 of 19
stefanveurink68AXD
Yeah, since delegate has to be defined before promptselection, and promptselection has to be defined before loop, I tried to change the delegate in the
    //here
but isn't working either. Probably because delegate is not changing if PromptSelection isn't finished yet. Little weird but okay.
Did you test your code? Because when I do I don't see any keywords appearing at all... to be honest nothing really happens (seems to). You just can do a selection, but nothing with keywords?
Message 14 of 19
ActivistInvestor
Perhaps I didn't explain clearly enough. The code I posted works, but you may have been expecting it to do something it wasn't intended to do. It only shows how to call GetSelection() in a loop, and exit the loop when the user enters a keyword, by using an exception, and also shows how to add another keyword to the prompt. To change the keywords, you must exit the inner loop by throwing the exception. When it's caught you can then modify the keywords.
It might also help to point out that once GetSelection() is called, and up to the point when it returns, the PromptSelectionOptions you pass to it, is effectively read only, and any changes made to it from within a keyword input event handler will be ignored until the PromptSelectonOptions is again passed into a subsequent call to GetSelection().
In other words there are two loops. One is the loop within GetSelection() that iterates each time the user responds with a keyword. The only way to exit that internal loop is by throwing an exception that is caught within the outer loop. The other "outer" loop repeatedly calls GetSelection() with the same PromptSelectionOptions, which it can modify before each call to GetSelection() (e.g., to add/change/remove keywords).
Here is a slightly-more verbose version of the same code posted above, that displays a message each time you enter a keyword. Two of the keywords will exit the inner loop within GetSelection(), the "Change" keyword when entered, will add another keyword to the input prompt. The "Quit" keyword will exit both the inner and outer loops and return null.
      int i = 0;
         keyword = e.Input;
         editor.WriteMessage($"User entered keyword {e.Input}");
            throw new KeywordException(e.Input); // break out of inner loop
         // Otherwise, Select Objects: prompt is re-issued
         // with the same keywords.
      while(true)
         try
            string suffix = pso.Keywords.GetDisplayString(true);
            pso.MessageForAdding = $"\nSelect objects or {suffix}";
            editor.WriteMessage($"\nGetSelection() exited, keyword = {ex.Keyword}");
            continue;
         return result;
      string keyword;
      if(psr == null)
      else
And here's what happens when I run it:
Command: SELECTWITHKEYWORDS
Select objects or [FIrst/Second/Third/Quit/Change]: First
User entered keyword FIrst
Select objects or [FIrst/Second/Third/Quit/Change]: Second
User entered keyword Second
Select objects or [FIrst/Second/Third/Quit/Change]: Change
User entered keyword Change
GetSelection() exited, keyword = Change
Select objects or [FIrst/Second/Third/Quit/Change/NewKeyword]: NewKeyword
User entered keyword NewKeyword
Select objects or [FIrst/Second/Third/Quit/Change/NewKeyword]: quit
User entered keyword Quit
GetSelection() exited, keyword = Quit
User chose Quit
Command:
Message 15 of 19
stefanveurink68AXD
Well, I see what you are trying to do, but when I run it it doesn't work.... it does everything you say, only when I choose 'change'  it just gives me the option to select, nothing else happens. Others are the same as you posted above.
Only difference might be I'm calling it from another class (toolpallete). But I don't see how that should matter.
I'll work on it, any ideas are welcome..
Message 16 of 19
ActivistInvestor
The calling context most certainly does matter. If you are calling it from the application context such as from The Click Handler of a button on a tool pallet or something like that then it may not behave the way it will when called from the Handler of a registered command.
I generally avoid executing code from the application context and instead place the code in a registered command Handler and then just execute the command from the application context.
Message 17 of 19
ActivistInvestor
 I'm not sure if you copied the code verbatim or not, but I just checked and the code I posted works from any calling context. E.g., from the click handler of a button on a Palette (application context), or from the registered command handler (document context).
From the click handler of a button (application context):
Select objects or [FIrst/Second/Third/Quit/Change]: first
User entered keyword 'FIrst'
Select objects or [FIrst/Second/Third/Quit/Change]: second
User entered keyword 'Second'
Select objects or [FIrst/Second/Third/Quit/Change]: change
User entered keyword 'Change'
GetSelection() exited, keyword = 'Change'
Select objects or [FIrst/Second/Third/Quit/Change/NewKeyword]: newkeyword
User entered keyword 'NewKeyword'
User entered keyword 'Quit'
GetSelection() exited, keyword = 'Quit'
User chose Quit
So, unless there's some difference in the code you're using, then the only other possibility is the AutoCAD release you're running on. There have been subtle changes over the last 3 or 4 major releases.
Message 18 of 19
stefanveurink68AXD
Im running it at autocad 2024, .net-framework is 4.8.
Will try some things when I got time, but i litteraly just pasted your code into mine, so i'm 100% it's exactly the same
Message 19 of 19
ActivistInvestor
Have you tried running the command that's included in the code that I posted?
