Project drawing setup plugin
jwylie2020
jwylie2020
Does anyone have the know how to create a plugin to copy drawing files from a common server folder location to a project specific folder location. The user would check "base" files to be created and plan sheet files to be created. The user would also add a project number to be added to the beginning to each created dwg file. Dwg "template" files would begin with XXXX, the x's would be renamed by the user input. Example: XX-XXXX SITE.dwg to 25-0610 SITE.dwg.
Ideally the user would have a dialog box to input info.
It looks like .NET could make a plugin with a dialog box like this. See what attached gemini wrote based on my prompt. This could be a starting point. From what I have read visualstudio code could be used to make a .dll file.
Has anyone done something like this?
JL
C3D 2024
Win 11 Pro
Sea-Haven
There is no reason as to why it can not be done in lisp, just need a image of the dcl as a dwg, then if your lucky someone will make you a dcl, copying files is a simple task in lisp. You can select a directory to copy and make a destination directory. There are VL commands to do that.
jwylie2020
So far I got this far: A dialog box opens with available drawings to select and a field to enter a destination path. An OK and Cancel button. After filling out the error shows"; error: bad argument type: stringp nil"
Items to update: Fix the error, ability to select more than one drawing with shift/ctrl or select with checkboxes. Add field to enter project number and rename drawing name Xs with entered project number field.
I will work on these item.
JL
C3D 2024
Win 11 Pro
paullimapa
For multiple list box selections add to dcl under your list_box this property
  multiple_select = true
Checkout this thread on how to retrieve the returned value
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-to-select-multiple-text-in-a-dia...
For destination path you may want to incorporate Lee Macs Browse For Folder:
https://www.lee-mac.com/directorydialog.html
Paul Li
IT Specialist
@The Office
