Programmatically locked layers won't fade
Paulio
Paulio
I have the following sub:
{code}
''' (summary) Locks or unlocks all layers in the drawing (summary)
''' (param name="Lock") Set to True if layers are to be locked or False to unlock (/param)
''' (remarks) If locking, the current layer is left unlocked (/remarks)
Public Sub LockLayers(ByVal Lock As Boolean)
Dim db As Database = HostApplicationServices.WorkingDatabase
Using trans As Transaction = db.TransactionManager.StartTransaction
Dim lt As LayerTable = trans.GetObject(db.LayerTableId, OpenMode.ForWrite)
For Each objID As ObjectId In lt
Dim ltr As LayerTableRecord = trans.GetObject(objID, OpenMode.ForRead)
Dim curLayer As ObjectId = db.Clayer
If curLayer <> objID Then
ltr.UpgradeOpen()
ltr.IsLocked = Lock
Next
trans.Commit()
End Using
End Sub
{code}
It works fine and locks all the layers (except the current one) but the locked layers don't fade out as they do when it's done through the layer manager.
I can get them to fade if I set the LAYLOCKFADECTL system variable but i can't then get them to "un-fade" when they're unlocked using the same method.
I'd rather not have to set the system variable anyway.
I've tried regen and updatescreen but no joy.
Is there something else I need to update/refresh to get them to grey-out properly?
Thanks.
You have to set the LAYLOCKFADECTL after you're through modifying the layers...no way around it.
SRSDS
I've worked out that for unlocking you can toggle the LAYLOCKFADECTL off and on to  give the drawing a kick.
Dim int As Integer = Application.GetSystemVariable("LAYLOCKFADECTL")
Application.SetSystemVariable("LAYLOCKFADECTL", 0)
Application.SetSystemVariable("LAYLOCKFADECTL", int)
