Problems with ResultBuffer
ZoltanFerenczy
ZoltanFerenczy
I have had some interesting problems sending data from Lisp to .NET applications with ResultBuffers, so I decided to be a simple test:
I created the following powerfull and complex application:
[LispFunction("Bounce")]
public static ResultBuffer Bounce(ResultBuffer args)
   return args;
When I send it certain lists of integers from AutoCAD's Lisp Console, funny things happen:
_$ (Bounce '(2001 0 0))
((2001.0 0.0 0.0))
_$ (Bounce '(2002 0 0))
((2002.0 0.0 0.0))
_$ (Bounce '(2003 0 0))
((2003.0 0.0 0.0))
_$ (Bounce '(2009 0 0))
((2009.0 0.0 0.0))
So far so good...well, kinda, except it is turning a list of three integers into a 3D Point, but this is a known issue. It get's better:
_$ (Bounce '(2010 0 0))
; error: LsAdsInvoke Internal Error
_$ (Bounce '(2011 0 0))
_$ (Bounce '(2012 0 0))
_$ (Bounce '(2013 0 0))
_$ (Bounce '(2014 0 0))
_$ (Bounce '(2015 0 0))
_$ (Bounce '(2016 0 0))
_$ (Bounce '(2017 0 0))
_$ (Bounce '(2018 0 0))
_$ (Bounce '(2019 0 0))
It get's funnier still:
_$ (Bounce '(3010 0 0))
(nil)
_$ (Bounce '(3011 0 0))
(nil)
_$ (Bounce '(3012 0 0))
(nil)
_$ (Bounce '(3013 0 0))
(nil)
_$ (Bounce '(3014 0 0))
(nil)
_$ (Bounce '(3015 0 0))
(nil)
_$ (Bounce '(3016 0 0))
_$ (Bounce '(3017 0 0))
_$ (Bounce '(3018 0 0))
_$ (Bounce '(3019 0 0))
_$ (Bounce '(3020 0 0))
((3020.0 0.0 0.0))
And finally:
_$ (Bounce '(3010 1 0))
; error: Exception occurred: 0xC0000005 (Access Violation)
; warning: unwind skipped on exception
_$ (Bounce '(3011 1 0))
_$ (Bounce '(3012 1 0))
Does anyone know what is causing this and how to get around it?
dgorsman
Maybe check the values against DXF codes?  There is a known issue when it receives certain value/patterns it will attempt to process them as DXF code lists just as it does with a list of three reals as a point.  Rather than bouncing the ResBuff contents directly back, I'd recommend stepping through the code and inspecting the values.  Then construct a new ResBuff, fill it with appropriate value types and values, and see how that gets passed back.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
ZoltanFerenczy
There are no DXF codes above 1000 - 1071, which are the Extended Entity Data codes. I can't step through the code, becuase the crash happens even before the ResultBuffer makes it to the Bounce function.
