problem with constructor
I want to inform user the name of command immediately when they netload my dll. I use the constructor like this way:
public class Control
        public Control()
            Editor acDoc = Application.DocumentManager.MdiActiveDocument.Editor;
            acDoc.WriteMessage("Type ABC to start");
        [CommandMethod("abc", CommandFlags.UsePickSet)]
        public void MyForm_start()
            MyForm fr = new MyForm();
            Application.ShowModalDialog(fr);
But it only write to command line when call abc command. Pls help!
Hallex
Try use
Autodesk.AutoCAD.ApplicationServices.Application
instead of Application
_____________________________________
C6309D9E0751D165D0934D0621DFF27919
Thank you, but it's still not right. I need after user call 'netload' and select my dll file. it will show some information to autocad command line.
Thank again.
DiningPhilosopher
The class that contains your command methods is not constructed until the first time one of the commands is used.
You have to use IExtensionApplication.Initialize() to display a message when your assembly is Netloaded.
Thank you so much. I can do it already.
    public class Control : Autodesk.AutoCAD.Runtime.IExtensionApplication
        public void Initialize()
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            ed.WriteMessage("Type ABC to start.");
        public void Terminate()
            Console.WriteLine("Cleaning up...");
