Private class function
Ed__Jobe
Mentor Mentor
Ed__Jobe
I want to have a function in a form that doesn't have a return type, it just sets some form controls. Something like the following.
private void SetList { }
However, I get error CS0547 that a property or indexer cannot have a void type. The method doesn't need a return type or any arguments. The problem is that VS thinks it's a property.
Ed
How to post your code.
kerry_w_brown
How about
private void SetList()
   //here be dragons
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Ed__Jobe
I think that is the same as what I have. I also think that the problem stems from the fact that the method exists in a form's partial class. The syntax you showed is fine in a regular class. That's the only difference I can see.
    public partial class frmGetFilesFromFolder : Form
        public frmGetFilesFromFolder()
            InitializeComponent();
        public void SetList()
I went ahead and abandoned this form, though. However, I would like to still understand the problem.
Ed
kerry_w_brown
Hi Ed,
In C# a Method requires parentheses.
Without parentheses the compiler thinks the declaration is a property or indexer.
The OP is absent parentheses.
Interesting point about partial classes but I'd need to test before commentng on that unusual case.
Ed__Jobe
Duh! I didn't catch that. Been away from programming in C# for too long.
Ed
