princ equivalent in c-sharp?
ganderson
ganderson
I'd like to do an equivalent to:
  (princ "All values set successfully") in C-sharp, ie this line appears on the command line when the function completes. Does anyone know or have an example?
                            ~Vonnie
_gile
Anything wrong with the Editor.WriteMessage() method ?
Gilles Chanteau
GileCAD
GitHub
ganderson
Don't know it. Can you point me to some documentation?
                     ~Giovonnae
kerry_w_brown
                     ~Giovonnae
Do you have arxmgd.chm from the ObjectArx SDK ??
or done a Google Search ???
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
kerry_w_brown
or this , from the AutoCAD DotNet Training Labs
http://usa.autodesk.com/adsk/servlet/index?id=1911627&siteID=123112
http://images.autodesk.com/adsk/files/autocad2016_dot_net_training.zip
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
namespace Lab1
    public class Class1
        [CommandMethod("HelloWorld")]
        public void HelloWorld()
            Editor ed =  Application.DocumentManager.MdiActiveDocument.Editor;
            ed.WriteMessage("Hello World");
