PlotSettingsValidator.SetClosestMediaName
Message 1 of 1
I'm trying to solve the problem of using an Access Database with my Pagesetups stored there, then loading these programatically into Acad. I need to input media names but would rather input the height & width. As each time our printers are updated or traded for new ones the papermedia names change depending on the drivers. I'd like this to be as dynamic as possible without relying on the variable my print drivers introduce to the equation.
Referencing Kean's blog: http://through-the-interface.typepad.com/through_the_interface/2007/10/allowing-select.html
Another approach for setting the media name is to use PlotSettingsValidator.SetClosestMediaName() to choose the media name that most closely matches the paper size you desire.
Anyone ever used the .SetClosestMediaName function?
I'm thinking this method would solve my problem. Any experience on this ?
Once I set the MediaName I still need that name for adding a new plotconfigurationname
If it changes or it slightly off... then what?
- psv.SetPlotConfigurationName(pl, sPlotDeviceName, sCanonicalMediaName)
My AddPlotConfig Method
 Public Sub AddPlotSetting_ToCurrentLayout_VBNET( _
                    ByVal sPageSetupName As String, _
                    ByVal sPlotDeviceName As String, _
                    ByVal sCanonicalMediaName As String, _
                    ByVal dPaperHeight As Double, _
                    ByVal dPaperWidth As Double, _
                    ByVal iPlotType As Autodesk.AutoCAD.DatabaseServices.PlotType, _
                    ByVal isPlotCentered As Boolean, _
                    ByVal iFitToPaper As StdScaleType, _
                    ByVal isStandardScale As Boolean, _
                    ByVal sStyleSheetName As String, _
                    ByVal isPlotStylesOn As Boolean, _
                    ByVal iPlotRotation As PlotRotation, _
                    ByVal xOffset As Double, _
                    ByVal yOffset As Double, _
                    ByVal isPlotDefault As Boolean)
        ed.WriteMessage("SetupName: " & sPageSetupName & Environment.NewLine)
        ed.WriteMessage("DeviceName: " & sPlotDeviceName & Environment.NewLine)
        ed.WriteMessage("MediaName: " & sCanonicalMediaName & Environment.NewLine)
        ed.WriteMessage("CTB: " & sStyleSheetName & Environment.NewLine)
        Try
            'STEP 1. Open Drawing Transaction
            'Use Current Active Drawing
            Dim CurrentDatabase As Database = Application.DocumentManager.MdiActiveDocument.Database
            'Open Transaction
            Using currentTransaction As Transaction = CurrentDatabase.TransactionManager.StartTransaction
                '2. Get (Active/Current) Layout ID (Model/Paper Space)
                Dim layoutId As ObjectId = LayoutManager.Current.GetLayoutId(LayoutManager.Current.CurrentLayout)
                Dim activeLyt As Layout = currentTransaction.GetObject(layoutId, OpenMode.ForRead)
                '3. Create New PlotSetting with
                'Create PlotSetting in LayoutObject (Write Mode)
                Dim pl As PlotSettings = New PlotSettings(True)
                '4. Use CopyFrom property of the plotsetting to intialize it on the Layout
                pl.CopyFrom(activeLyt)
                '4.B Use Plot Settings Validator
                'Create PlotSettingsValidator & Populate PlotSettings
                Dim psv As PlotSettingsValidator = PlotSettingsValidator.Current
                'Refresh Lists
                psv.RefreshLists(pl)
                '[1][PageSetup Name]
                pl.PlotSettingsName = sPageSetupName
                '[2-3][Printer/CanonicalMediaName] & [PaperSize]
                '[3] Set CanonicalMediaName
                Dim CanonicalList As StringCollection = psv.GetCanonicalMediaNameList(pl)
                'Test if CanonicalInputName is Valid
                If CanonicalList.Contains(sCanonicalMediaName) = True Then
                Else
                    MsgBox("Problem with " & sCanonicalMediaName)
                    'If Not Find Closest Media Name Match
                    psv.SetClosestMediaName(pl, dPaperWidth, dPaperHeight, PlotPaperUnit.Inches, True)
                '[2] Set the plot device to use
                'Validates if Printer Name exists in Windows
                Dim PrinterList As StringCollection = psv.GetPlotDeviceList
                If PrinterList.Contains(sPlotDeviceName) Then
                    '[2] Add Print Device
                Else
                    'Add Missing Printer to Computer
                    Func.AddPrinterToComputer(Trim(sPlotDeviceName))
                    'Refresh (Rebuilds the plot, canonical media, and plot style table arrays to reflect the current system state)
                    'Error Message
                    If PrinterList.Contains(sPlotDeviceName) = False Then
                        MsgBox("Can't Find Printer Named: " & sPlotDeviceName & vbCrLf & _
                               "This Page Setup Will Not Load Properly")
                        Exit Sub
                '[4][Plot Area]
                psv.SetPlotType(pl, iPlotType)
                '[5][Plot Offset]
                psv.SetPlotOrigin(pl, GetOffsetPoint(xOffset, yOffset))
                '[6][Center the Plot]
                'Center the plot
                psv.SetPlotCentered(pl, isPlotCentered)
                '[7][Plot Fit To Paper]
                psv.SetStdScaleType(pl, iFitToPaper)
                '[8][Plot Scale]
                psv.SetUseStandardScale(pl, isStandardScale)
                '[10][Plot Style Table] (Pen Assignments)
                Dim StyleList As StringCollection = psv.GetPlotStyleSheetList
                If StyleList.Contains(sStyleSheetName) Then
                    psv.SetCurrentStyleSheet(pl, sStyleSheetName)
                Else
                    MsgBox("Can't Find PenTable Name: " & sStyleSheetName & vbCrLf & _
                    Exit Sub
                '[Shaded viewport Options]
                '[11][Plot Options]
                pl.PlotPlotStyles = isPlotStylesOn
                'pl.PrintLineweights = isPlotLineWeightsOn
                '[12][Drawing Orientation]
                psv.SetPlotRotation(pl, iPlotRotation)
                If isPlotDefault Then
                    'Make Default PageSetup Yes/No?
                    psv.SetDefaultPlotConfig(pl)
                '5. Add to the PlotSettings Dictionary (Adds to the Drawing Database)
                'Add to Plot Settings to Drawing Database
                pl.AddToPlotSettingsDictionary(CurrentDatabase)
                '6. AddNewlyCreatedDBOject to the Transaction (Adds it to the Transaction)
                'This Line of Code is essential
                currentTransaction.AddNewlyCreatedDBObject(pl, True)
                '7. Refresh the The Plotsettings with Plotsettings Validator
                '8. Commit Current Transaction
                'Commit Transaction & Save to Database
                currentTransaction.Commit()
            End Using
        Catch ex As Exception
            MsgBox(ex.Message)
        End Try
    End Sub
Replies (0)
