Part rebar calculation
Hello friends
I'm doing a study for iron footage, friends. How should I edit the code according to the algorithm in the dwg file I have attached. Is anyone available that can help?
Thanks.
[CommandMethod("demirPART")]
public void demirPart()
Document doc = Application.DocumentManager.MdiActiveDocument;
Database db = doc.Database;
Editor editor = doc.Editor;
editor.WriteMessage("Demir ağırlık hesabı için kolon açılımlarından Text Obje seçiniz..");
// Define the selection filter to select Text objects only
TypedValue[] filterList = new TypedValue[] {
new TypedValue((int)DxfCode.Start, "TEXT"),
SelectionFilter selectionFilter = new SelectionFilter(filterList);
// Prompt user to select Text objects
PromptSelectionResult selectionResult = editor.GetSelection(selectionFilter);
if (selectionResult.Status != PromptStatus.OK)
editor.WriteMessage("Text Obje seçilmedi.!");
return;
int sbCount = 0;
// Get the selected Text objects
//string ayriCaplar = "";
//List<int> capListesi = new List<int>();
//List<int> adetListesi = new List<int>();
//List<double> boyListesi = new List<double>();
//List<int> uniqueCaps = new List<int>();
using (Transaction tr = db.TransactionManager.StartTransaction())
SelectionSet selectionSet = selectionResult.Value;
foreach (SelectedObject selectedObject in selectionSet)
if (selectedObject.ObjectId.ObjectClass.DxfName == "TEXT")
DBText textObject = tr.GetObject(selectedObject.ObjectId, OpenMode.ForRead) as DBText;
if (textObject != null)
string text = textObject.TextString;
string sbPattern = @"(\.SB)|(S{1,3}|(P{1,3}))";//kolon veya perde adedi
MatchCollection sbMatches = Regex.Matches(text, sbPattern);
sbCount += sbMatches.Count;
//string dntPattern = @"(\d+)ø(\d+)\/?\d*?\s+?L=(\d+)";//kolon veya perde adedi
//MatchCollection dntMatches = Regex.Matches(text, dntPattern);
//foreach (var kayit in dntMatches)
// var rgx = new Regex(@"(\d+)ø(\d+)\/?\d*?\s+?L=(\d+)");
// var matches = rgx.Matches((string)kayit);
// if (matches.Count < 1) continue;
// capListesi.Add(int.Parse(matches[0].Groups[2].Value));
// adetListesi.Add(int.Parse(matches[0].Groups[1].Value));
// boyListesi.Add(double.Parse(matches[0].Groups[3].Value));
//var caP1 = capListesi.Distinct();
//foreach (int cp in caP1)
// uniqueCaps.Add(cp);
//for (int i = 0; i < uniqueCaps.Count; i++)
// double mysum = 0.0;
// for (int f = 0; f < capListesi.Count; f++)
// if (capListesi[f] == uniqueCaps[i])
// mysum += trg.Krs(uniqueCaps[i]) * 0.00617 * (adetListesi[f] * boyListesi[f] / 100) / 1000;
// ayriCaplar = ayriCaplar + "ø" + uniqueCaps[i] + " = " + mysum.ToString("F3") + " ton" + "\n";
// System.Windows.Forms.MessageBox.Show(adetListesi + "\n", "Donatılar");
tr.Commit();
