Parallel DWG Reads
Parallel DWG Reads
Parallel DWG Reads
Hi.
My application (a .DLL which I netload in) accesses several DWGs selected in a windows form app and collects some block attribute info about them. How can I do this in parallel?
I don't need to save the DWG at all during processing.
DWG.cs:
public class DWG
	public string DWGLocation;
	public string DWGName;
	public string DWGRev;
	public List<string> DWGLayouts;
	public string PDFName;
	public bool PDFExists;
	public bool IsDWGLocked;
	public bool IsPlotPDFLocked;
	public bool IsHistoricalPDFLocked;
	public bool IsReviewPDFLocked;
	// Class constructor based on passed parameter
	public DWG(string dwgToProcess)
		DWGLocation = dwgToProcess;
		DWGName = Path.GetFileName(DWGLocation);
		PDFExists = File.Exists(FileOps.Path(DWGLocation) + GlobalVals.plotDir + PDFName);
		IsDWGLocked = FileOps.IsFileLocked(DWGLocation);
		IsPlotPDFLocked = FileOps.IsFileLocked(FileOps.Path(dwgToProcess) + GlobalVals.plotDir + PDFName);
		IsHistoricalPDFLocked = FileOps.IsFileLocked(FileOps.Path(dwgToProcess) + GlobalVals.historicalDir + PDFName);
		IsReviewPDFLocked = FileOps.IsFileLocked(FileOps.Path(dwgToProcess) + GlobalVals.reviewDir + PDFName);
		// Get the rev num and layout names from the DWG
		try
			DWGRev = "?";
			List<string> layouts = new List<string>();
			using (Database db = new Database(false, true))
				db.ReadDwgFile(dwgToProcess, FileShare.Read, false, null);
				db.CloseInput(true);
				using (Transaction tr = db.TransactionManager.StartTransaction())
					// Layouts
					DBDictionary layoutDict = (DBDictionary)db.LayoutDictionaryId.GetObject(OpenMode.ForRead);
					foreach (DBDictionaryEntry entry in layoutDict)
						if (entry.Key != "Model")
							ObjectId layoutId = entry.Value;
							Layout layout = tr.GetObject(layoutId, OpenMode.ForRead) as Layout;
							layouts.Add(layout.LayoutName);
					DWGLayouts = layouts;
					// Attribute
					var bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
					if (bt.Has(GlobalVals.titleblock))
						// Open the block definition
						var btr = (BlockTableRecord)tr.GetObject(bt[GlobalVals.titleblock], OpenMode.ForRead);
						// Get the inserted block references ObjectIds
						var ids = btr.GetBlockReferenceIds(true, true);
						if (ids.Count > 0)
							// Open the first block reference
							var br = (BlockReference)tr.GetObject(ids[0], OpenMode.ForRead);
							// Iterate through the attribute collection
							foreach (ObjectId id in br.AttributeCollection)
								// Open the attribute reference
								var attRef = (AttributeReference)tr.GetObject(id, OpenMode.ForRead);
								// If the attribute tag is what we are searching for
								if (attRef.Tag.Equals(GlobalVals.revtag, StringComparison.CurrentCultureIgnoreCase))
									DWGRev = attRef.TextString == "" || attRef.TextString == " " ? "R0" : attRef.TextString;
									break;
					tr.Commit();
			// Remove any spaces in the front or end of the REV val with trim in case of bad input
			DWGRev.Trim();
			PDFName = PDFOps.GetPDFName(DWGLocation, DWGRev);
		catch (System.Exception ex)
			ErrorHandler.ErrorReport(ex, "GetRevNum", "notify");
I create multiple instances of DWG like so:
foreach (string dwg in dialog.FileNames)
	// Check if the DWG already exists in list view to prevent duplicates in list view and list
	if (this.DwgList.FindItemWithText(dwg) == null)
		// Create an instance of a DWG
		var dwgEntry = new DWG(dwg);
		// Make sure DWG is not locked
		if (!dwgEntry.IsDWGLocked)
			// Make sure no PDFs are locked
			if (!dwgEntry.IsPlotPDFLocked && !dwgEntry.IsHistoricalPDFLocked && !dwgEntry.IsReviewPDFLocked)
				// Add the item to the List & list view
				GlobalVals.dwgs.Add(dwgEntry);
				AddListViewItem(dwgEntry);
			else
				// Some or all of the PDFs are locked
				foreach (string error in FileOps.WhichPDFsAreLocked(dwgEntry))
					errors.Add(error);
		else if (dwgEntry.IsDWGLocked)
			errors.Add("The drawing " + dwgEntry.DWGName + " is currently open by a user.");
	else
		errors.Add("The drawing " + Path.GetFileName(dwg) + " is already in the list.");
I tried doing it in parallel here, which crashed my AutoCAD:
Parallel.ForEach(dialog.FileNames,  (dwg) = >
	// Same body code as above
Later in my code, I create a consolidated DSD file from the information in DWG object and send it to the publisher.
micle.space
just a quick result for a quick research on this forum:
https://forums.autodesk.com/t5/net/parallel-read-from-net/m-p/6397148
some quoted text: "...There is no parallel processing in AutoCAD.  For better performance I would first suggest... "
https://forums.autodesk.com/t5/net/parallel-loop/m-p/3726470
again some quoted text: "...Sorry for the bad news, but the AutoCAD API isn't thread safe. You can.... "
