Overriding LayerTableRecord's visibility per View/ViewRecord
Message 1 of 11
I am having problems with users with multiple viewports - changes in one window are affecting another. After some digging, I have established this is because I am changing the visibility of the layer table record on a global basis - I change one viewport and change the layer table records' visibility for it, but this is global and affects other open viewports. I've seen there is a .GetViewportOverrides method on the LayerTableRecord object but this doesn't seem to allow the .IsOff property to be overridden. Am I missing something?
Replies (10)
Message 2 of 11
Alexander.Rivilis
You can not off layer(s) in viewport, but can freeze layer(s) in viewport:
https://help.autodesk.com/view/ACD/2022/ENU/?guid=GUID-04F71808-2FFA-4BFE-A3C5-7FD418A63B4C
It can be done with help of Viewport.FreezeLayersInViewport  method.
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
Message 3 of 11
Thanks, that's helpful. I can't find a programmatic example though. The viewport overrides in C# seem to have options for Transparency, Line weight, etc but nothing for ffreezing?
Message 4 of 11
SENL1362
in short:
var layersToFreeze = new ObjectIdCollection();
var layersToThaw = new ObjectIdCollection();
//add layers to each collection
var pvp = (Viewport)tr.GetObject(vpId, OpenMode.ForWrite);
pvp.FreezeLayersInViewport(layersToFreeze.GetEnumerator());
pvp.ThawLayersInViewport(layersToThaw.GetEnumerator());
//Don't forget to dispose the Collections
Message 5 of 11
Thanks. I'm now stuck getting hold of the viewport instance (or the vpId in your example). Editor.CurrentViewportObjectId is 0; Editor.ActiveViewportId I can get a ViewTableRecord but not a Viewport; LayoutManager not returning anything either....
Message 6 of 11
Alexander.Rivilis
Editor.CurrentViewportObjectId is 0 if you in ModelSpace. But if you in PaperSpace Editor.CurrentViewportObjectId is not 0.
Expert Elite Member
Message 7 of 11
Ah, thanks. Yes, I'm in ModelSpace.
Message 8 of 11
Alexander.Rivilis
But viewports are in PaperSpace...
Expert Elite Member
Message 9 of 11
Maybe I'm confused then. I have a DWG file open with the screen divided into two parts, side-by-side, with the split vertical. That's the 'Viewport Configuration' I set from that option on the View menu. ???
Message 10 of 11
Alexander.Rivilis
You can only freeze/thaw layers in PaperSpace viewport, but not in ModelSpace viewport.
Expert Elite Member
Message 11 of 11
Right, so everything I'm trying is pointless! Ok, thanks.
