OjectARX or C# + external DLL?
oransen
oransen
Though I programmed in ObjectARX many years ago I'm thinking that it may be better to use C# (running as a plugin in AutoCAD) which calls functions in an external DLL.
The C# would be mainly GUI and DWG database stuff, while the DLL would do complex calculations.
Is that a sensible approach?
ObjectARX seems to require recompilation with almost every release of AutoCAD, presumably C# programs don't need to be updated so often. Is that right?
Virupaksha_aithal
Autodesk Support
Autodesk Support
I agree with your approach as many developers has taken this approach.
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
