Objects not being drawn in jig
a.kouchakzadeh
Message 1 of 1
a.kouchakzadeh
Hey everyone
I'm trying to mimic a hovering effect with my jig, I don't think I need to go into details since my problem seems to lie in Autocad'ss jig's worldDraw method. I have written the method bellow in a class that is injected into the worldDraw method of my jig:
        public void Draw(WorldDraw draw, Point3d point)
            var ed = Application.DocumentManager.MdiActiveDocument.Editor;
            ed.UpdateScreen();
            // Highlight regions
            foreach (var region in _regionsToHighlight) {
                region.ColorIndex = 1;
                region.LineWeight = LineWeight.LineWeight100;
                draw.Geometry.Draw(region);
            var closestPointUnRound =
PointUtils.GetClosestPointToFast(point.Convert2d(), _Kd2Tree);
            var closestPoint = LocalUtils.RoundPoint(closestPointUnRound.Convert3d());
            if (!_centroidDict.ContainsKey(closestPoint))
                return;
            var reg = _centroidDict[closestPoint];
            if (!Check.IsPointInside(reg, point))
                return;
            reg.ColorIndex = 3;
            draw.Geometry.Draw(reg);
            if (_centoidTextDict.ContainsKey(closestPoint))
                var text = _centoidTextDict[closestPoint];
                text.Height = 100;
                text.ColorIndex = 1;
                draw.Geometry.Draw(text);
 Here is the worldDraw of my jig function:
protected override bool WorldDraw(WorldDraw draw)
    if (_jigWorldDraw != null)
        _jigWorldDraw.Draw(draw, _point);
    return true;
as you can see nothing special here.
So the problem is I have many objects that need to be drawn, and even though my break point at the draw.Geometry.Draw seems to be hit(forexample for the text) the text isn't being drawn. only a handful of the objects are being drawn. any help would be appreciated.
Replies (0)
