I'm trying to create a routine that
change BlockTableRecord in BlockReference
when copying
use ObjectOverrule with a custom DeepClone
source block with attributes
everything turns out well
but then when you manual change the new block of a fatal error occurs
new block - rotated, scaled, change attributes, and copy to clipboard - fatal error
please correct my code
look at the line
bref.BlockTableRecord = newbtr.Id;
using System; using System.Text; using System.ComponentModel; using System.Collections; using System.Collections.Generic; using System.IO; using System.Runtime.InteropServices; using System.Text.RegularExpressions; using Autodesk.AutoCAD.ApplicationServices; using Autodesk.AutoCAD.DatabaseServices; using Autodesk.AutoCAD.Runtime; using Autodesk.AutoCAD.EditorInput; using Autodesk.AutoCAD.Geometry; using Autodesk.AutoCAD.Windows; using Autodesk.AutoCAD.GraphicsInterface; using MgdAcApplication = Autodesk.AutoCAD.ApplicationServices.Application; using DSe = Autodesk.AutoCAD.DatabaseServices; [assembly: ExtensionApplication(typeof(test20_Namespace.Init))] [assembly: CommandClass(typeof(test20_Namespace.Commands))] namespace test20_Namespace { public class Init : Autodesk.AutoCAD.Runtime.IExtensionApplication { public void Initialize() { ObjectOverrule.AddOverrule(RXClass.GetClass(typeof(Autodesk.AutoCAD.DatabaseServices.BlockReference)), CopyOverrule.theOverrule, true); DrawableOverrule.Overruling = true; } public void Terminate() { } } public class CopyOverrule : ObjectOverrule { static public CopyOverrule theOverrule = new CopyOverrule(); public CopyOverrule() { } public override DBObject DeepClone( DBObject dbObject, DBObject ownerObject, IdMapping idMap, bool isPrimary ) { // First we deep clone the object via the parent DBObject res = base.DeepClone(dbObject, ownerObject, idMap, isPrimary); // Check if its our block if (res != null) { Database db = HostApplicationServices.WorkingDatabase; using (Transaction tr = db.TransactionManager.StartTransaction()) { BlockTable blockTable = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead); // Get BlockRefrence object BlockReference bref = (BlockReference)res; // find a back reference BlockTableRecord btrec = (BlockTableRecord)tr.GetObject(bref.BlockTableRecord, OpenMode.ForRead); BlockTableRecord newbtr = new BlockTableRecord(); blockTable.UpgradeOpen(); newbtr.Name = "*U"; ObjectId newBtrId = blockTable.Add(newbtr); tr.AddNewlyCreatedDBObject(newbtr, true); ObjectIdCollection ids = new ObjectIdCollection(); foreach (ObjectId id in btrec) { ids.Add(id); } IdMapping idM = new IdMapping(); db.DeepCloneObjects(ids, newBtrId, idM, true); bref.BlockTableRecord = newbtr.Id; tr.Commit(); } } return res; } } public class Commands { static bool overruling = true; [CommandMethod("GOO2")] public static void GripOverruleOnOff() { Document doc = Application.DocumentManager.MdiActiveDocument; Editor ed = doc.Editor; if (overruling) { ObjectOverrule.RemoveOverrule(RXClass.GetClass(typeof(Autodesk.AutoCAD.DatabaseServices.BlockReference)), CopyOverrule.theOverrule); } else { ObjectOverrule.AddOverrule(RXClass.GetClass(typeof(Autodesk.AutoCAD.DatabaseServices.BlockReference)), CopyOverrule.theOverrule, true); } DrawableOverrule.Overruling = !overruling; overruling = !overruling; ed.WriteMessage("\nEnable {0}.", overruling ? "on" : "off"); } } }
