ObjectId OpenAs
ObjectId OpenAs
David_Prontnicki
ObjectId OpenAs
David_Prontnicki
I have an older method I wrote and it is still working in other programs written prior. But when creating a new one, I can not use the same method anymore as it tells me "OpenAs is not a member of ObjectId". Has this changed or am I missing something?
    Public Sub BurstAllBlocks()
        Dim curDb As Database = Active.Database
        Try
            Using tr As Transaction = curDb.TransactionManager.StartTransaction()
                Dim layoutDbDictionary As DBDictionary = tr.GetObject(curDb.LayoutDictionaryId, OpenMode.ForRead)
                For Each layoutDbDictionaryEntry As DBDictionaryEntry In layoutDbDictionary
                    Dim layout As Layout = CType(layoutDbDictionaryEntry.Value.GetObject(OpenMode.ForRead), Layout)
                    Dim blkTblRec As BlockTableRecord = tr.GetObject(layout.BlockTableRecordId, OpenMode.ForWrite)
                    Dim rxClass = RXObject.GetClass(GetType(BlockReference))
                    Dim blocks = blkTblRec.Cast(Of ObjectId).Where(Function(ent) ent.ObjectClass.IsDerivedFrom(rxClass)) _
                        .Select(Function(ent) ent.OpenAs(Of BlockReference)(tr, OpenMode.ForRead))
                    For Each block As BlockReference In blocks
                        BurstBlocks(tr, block, blkTblRec)
                    Next
                Next
                tr.Commit()
            End Using
        Catch ex As Exception
            MessageServices.DisplayError("Error Bursting Blocks!", "Click OK to skip this section and continue.", ex)
        End Try
    End Sub
_gile
As far as I know the ObjectId type never had such OpenAs method (see ObjectId methods).
This is certainly an extension method which was part of your "other programs written prior".
Gilles Chanteau
GileCAD
GitHub
David_Prontnicki
@_gile
I forgot about an extension I was using to make that happen. If anyone else is interested here it is:
Imports System.Runtime.CompilerServices
Imports Autodesk.AutoCAD.DatabaseServices
Module DBObjectExtensions
    <Extension()>
    Public Function OpenAs(Of T As DBObject)(ByVal objectId As ObjectId, tr As Transaction, openMode As OpenMode)
        Return DirectCast(tr.GetObject(objectId, openMode), T)
    End Function
End Module
