ObjectID from Dictionary Unable to cast object of type to type Polyline
Sgear
Message 1 of 8
Sgear
Hi
I am try to use ObjectID from Dictionary and send it to test to get Polyline Length
I get this error
System.InvalidCastException: Unable to cast object of type 'Autodesk.AutoCAD.DatabaseServices.DataTable' to type 'Autodesk.AutoCAD.DatabaseServices.Polyline'.
     Public Sub getDictionary()
            Dim doc As Document = Application.DocumentManager.MdiActiveDocument
            Dim db As Database = doc.Database
            Using trans As Transaction = db.TransactionManager.StartTransaction()
                Dim NOD As DBDictionary = trans.GetObject(db.NamedObjectsDictionaryId, OpenMode.ForRead, False)
                Dim NetworkDict As DBDictionary
                Try
                    NetworkDict = trans.GetObject(NOD.GetAt("ACAD_OC"), OpenMode.ForRead)
                Catch ex As Autodesk.AutoCAD.Runtime.Exception
                    MsgBox(ex.Message)
                    Exit Sub
                End Try
                Dim DictEnum As DbDictionaryEnumerator = NetworkDict.GetEnumerator()
                While DictEnum.MoveNext
                    Dim PageDict As DBDictionary = DirectCast(trans.GetObject(DictEnum.Value, OpenMode.ForRead), DBDictionary)
                    For Each eDict As DictionaryEntry In PageDict
                        Test66(eDict.Value)
                    Next
                End While
            End Using
        End Sub
       Public Sub Test(ByVal objId As ObjectId)
                 Dim doc As Document = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Dim ed As Editor = doc.Editor
            Dim Length As Double
            Using doc.LockDocument()
                Using tr As Transaction = db.TransactionManager.StartTransaction()
                    Dim obj As DBObject = tr.GetObject(objId, OpenMode.ForRead)
                    If TypeOf (obj) Is BlockReference Then
                    Else
                        Dim l As Polyline = DirectCast(obj, Polyline)
                        Length = Length + l.Length.ToString
                    ed.WriteMessage(vbLf & Length)
                    tr.Commit()
                End Using
            End Using
        End Sub
Replies (7)
Message 2 of 8
_gile
So, isn't the exception message explicit ?
You cast a DBObject wich type is DataTable into a Polyline.
Rather than checking if the DBObject is not a BlockReference you should check if it is a Polyine
Not tested (VB is far to be my favorite language)
                    If objId.ObjectClass.DxfName = "LWPOLYLINE"
                        Dim l As Polyline = DirectCast(tr.GetObject(objId, OpenMode.ForRead), Polyline)
                    tr.Commit()
                End Using
            End Using
        End Sub
Gilles Chanteau
GileCAD
GitHub
Message 3 of 8
Sgear
Thanks _gile I can cast objectID between with your solution thanks for this !
Message 4 of 8
Sgear
Forgot the Lengt of the Polyline is 0 do I need to find the object in the Drawing with the ObjectID and then check the Length
Message 5 of 8
Sgear
The ObjectID from ACAD_OC and the ObjectID of the Polyline in the drawing are not the same.
when I close the drawing and open again I get new ID I did not know that I thought the ID was same after you create it
ACAD_OC  = (140695840146016)
Polyline  = (140695840145968)
Message 6 of 8
_gile
I do not konw anything about ACAD_OC dictionary (maybe a MAP specific dictionary?).
ObjectIds are not persistant and are re-created at document re-opening (see this thread).
If the dictionary entry is stored as HardPointerId, SoftOwnershipId, etc. the re-created ObjectIds of the polyline and the dictionary entry should be the same.
Sorry, I cannot help you further with AutoCAD MAP specific features.
Gilles Chanteau
GileCAD
GitHub
Message 7 of 8
_gile
Maybe you can attach a little drawing (dwg) with a polyline and a dictionary (but I'm not sure I can inspect it with AutoCAD Vanilla).
Gilles Chanteau
GileCAD
GitHub
Message 8 of 8
Sgear
ACAD_OC dictionary keep information about Definition File and Classify Object in the Drawing
the Class Name are always the same so I need to find in the forum if I can find object by Class Name not ObjectID
