objectdbx interop error during save run recover
I am trying to apply a btach process to thousands of DWG files.
Using c# objectdbx via interop.
Many of the DWG files stop at Save and display message: Warning: an error occured during save. we recommend that you run recover on the drawing.
Expert is set to 5. recoverauto is set to 3.
Is there a system variable to disable this save warning message?
Thx,
Kevin.
Virupaksha_aithal
Autodesk Support
Autodesk Support
Hi
This may not be much help to you. But my observation is most of the time this error message is because of drawing corruption. See if the drawing file gives same error if you run your routine on them manually.
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
Thank you.
Virupaksha_aithal
Autodesk Support
Autodesk Support
Sorry, i am not clear about your comment. Can you please clarify your comment?
Note: API and system variables are same for every one (A D N & non A D N).  A D N team answers questions in forum too. (questions of A D N members and non A D N members)
