OAuth with entitlement API
First of all, the question might seem dumb but I am a little bit confused, so please bear with me.
I want to use entitlment API with Autodesk Exchange store, so I need the AppId (which is available) and the UserId. For the UserId I can check the variable "ONLINEUSERID" or as suggested by this post, I can dispaly the Autodesk Log in and ask the user to log in.
I tried the code with the post but I don't know how I can get the "Consumer Key" and "Consumer Secret"! Any hints or answers are much appreciated.
kean_walmsley
Hi there,
You don't need a consumer key and secret to use this API, as far as I know.
Here's a blog post where I showed another way of using it:
http://through-the-interface.typepad.com/through_the_interface/2016/02/securing-your-autocad-app-usi...
Does it help?
Kean
Kean Walmsley
Platform Architect & Evangelist, Autodesk Research
Blog | Twitter
Virupaksha_aithal
Autodesk Support
Autodesk Support
My sugegstion is to use the entitlment API with "ONLINEUSERID". If ONLINEUSERID is empty, please promot the user to sign in A360. At present, there is no direct/easy method to get "Consumer Key" and "Consumer Secret".
Also, the post is old. To avoid getting "Consumer Key" and "Consumer Secret", we requested the developers to "ONLINEUSERID".
Please refer http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=24243865
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
Thanks so much for your reply,
I got the idea but I have a small follow-up. Can my software shows the log-in window instead of asking the user to use the log-in button in the AutoCAD interface?
kean_walmsley
Not in a way that's meaningful to AutoCAD: the sign in capability is built into AutoCAD's UI.
You could implement your own application's sign-in capability, but then you'd be on your own with respect to entitlement etc.
Kean
Kean Walmsley
Blog | Twitter
is there any option to get the 'ONLINEUSERID' by submitting the autodesk ID
