In a test project I am working on I am trying to use the FontAwesome.WPF NuGet package for icons to be displayed on a palette control. Here is the current solution structure
Solution
- Core.csproj (references UI.csproj for views)
- UI.csproj (the project that references the FontAwesome.WPF package)
In the WPF UserControl that needs the icons I have added the namespace declaration and usage of the icons like this
xmlns:fa="http://schemas.fontawesome.io/icons/"
<fa:ImageAwesome
Icon="Plus"
Width="16" Height="16"
Margin="0 0 5 0"/>
<TextBlock Text="Connect To Existing Project" />
Everything in the XAML designer renders fine. However, when I NETLOAD my plugin from bin/Debug/Core.dll and then trigger the command that shows my palette with the icons I get the following error at the InitializeComponent method in the code-behind my user control
System.Windows.Markup.XamlParseException
HResult=0x80131501
Message=Could not load file or assembly 'FontAwesome.WPF, PublicKeyToken=0758b07a11a4f466' or one of its dependencies. The system cannot find the file specified.
Source=PresentationFramework
StackTrace:
at System.Windows.Markup.XamlReader.RewrapException(Exception e, IXamlLineInfo lineInfo, Uri baseUri)
at System.Windows.Markup.WpfXamlLoader.Load(XamlReader xamlReader, IXamlObjectWriterFactory writerFactory, Boolean skipJournaledProperties, Object rootObject, XamlObjectWriterSettings settings, Uri baseUri)
at System.Windows.Markup.WpfXamlLoader.LoadBaml(XamlReader xamlReader, Boolean skipJournaledProperties, Object rootObject, XamlAccessLevel accessLevel, Uri baseUri)
at System.Windows.Markup.XamlReader.LoadBaml(Stream stream, ParserContext parserContext, Object parent, Boolean closeStream)
at UI.View.ProjectTabView.InitializeComponent() in C:\Users\jerem\source\repos\PluginUIDemo\UI\View\ProjectTabView.xaml:line 1
This exception was originally thrown at this call stack:
[External Code]
Inner Exception 1:
FileNotFoundException: Could not load file or assembly 'FontAwesome.WPF, PublicKeyToken=0758b07a11a4f466' or one of its dependencies. The system cannot find the file specified.
Now the part where I get really confused is that I have confirmed that the FontAwesome.WPF.dll is present in my output directory (bin/Debug/FontAwesome.WPF.dll). I also am referencing a MVVM NuGet package in UI.csproj in the same way and that works just fine (however the difference is this isn't being loaded during initialization of a user control).
<ItemGroup>
<PackageReference Include="CommunityToolkit.Mvvm">
<Version>8.3.2</Version>
</PackageReference>
<PackageReference Include="FontAwesome.WPF">
<Version>4.7.0.9</Version>
</PackageReference>
</ItemGroup>
Interestingly, I can fix this error by manually copying the FontAwesome.WPF.dll into the C:\Program Files\Autodesk\AutoCAD 2024 directory, which confirms that is where ACAD is looking for this package. What I don't understand is why ACAD is looking for this package in the program files directory (C:\Program Files\Autodesk\AutoCAD 2024) and not in the bin/Debug output directory where I indicated that my plugin dll is and all the other dlls that mine depends on are located. Is there something different about loading assemblies for user controls?
