'nother newbie question: area parameter
I'm using ACAD2008, Visual Studio Express 08 and am just starting out with this whole vb.net thing.
I "borrowed" some code Fatty posted here
http://discussion.autodesk.com/thread.jspa?messageID=5804172
and was wondering how to do a similar thing with LWpolyline area. I don't see a GetAreaatparameter.
Could somone point me in the right direction?
Thanks!!
I don't know why Fatty wasn't using the Length property. There is also an area property.
Thanks, Nathan
I don't remember why, perhaps it was written for
older version
~'J'~
Try these functions instead:
Public Shared Function TotalLength() As Double
Dim totlen As Double = 0
Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
Dim dxf() As TypedValue = {New TypedValue(DxfCode.Start, "LWPOLYLINE")}
Dim filt As New SelectionFilter(dxf)
Dim opts As PromptSelectionOptions = New PromptSelectionOptions
opts.MessageForAdding = "Select polylines to calculate the total length:"
opts.AllowDuplicates = False 'by suit
opts.SingleOnly = False
Dim res As PromptSelectionResult = ed.GetSelection(opts, filt)
If res.Status PromptStatus.OK Then
Return 0
Dim db As Database = HostApplicationServices.WorkingDatabase
Using tr As Transaction = db.TransactionManager.StartTransaction()
Dim sset As SelectionSet = res.Value
Dim IDs() As ObjectId = sset.GetObjectIds
Dim n As Integer = 0
For Each Id As ObjectId In IDs
Dim ent As Entity = tr.GetObject(IDs(n), OpenMode.ForRead)
Dim pl As Polyline = tr.GetObject(ent.ObjectId, OpenMode.ForRead)
Dim ln As Double = pl.Length
totlen = totlen + ln
n += 1
Next
MessageBox.Show(String.Format("Total length = {0}", totlen)) ' for debug only
tr.Dispose()
End Using
Return totlen
End Function
Public Shared Function TotalArea() As Double
Dim totar As Double = 0
Return 0
Dim ar As Double = pl.Area
totar = totar + ar
n += 1
Next
MessageBox.Show(String.Format("Total area = {0}", totar)) ' for debug only
tr.Dispose()
End Using
Return totar
End Function
~'J'~
