Not Skipping Attribute
Message 1 of 31
I have the below code as a means of transferring attribute values from one place to another.  Within it I'm trying to make it skip a specific attribute with a tag "INITIALS".  The message box within the code is there to test the If/Else/EndIf.  It works.  The message only pops up when it hits that attribute.  Yet the result is the attribute with the tag "INITIALS" is still added to the list.  Any ideas as to why it works but doesn't?
            Using AcTrans As Transaction = AcDb.TransactionManager.StartTransaction()
                Dim bt As BlockTable = AcTrans.GetObject(AcDb.BlockTableId, OpenMode.ForRead, False, True)
                For Each id As ObjectId In bt
                    Dim btr As BlockTableRecord = DirectCast(AcTrans.GetObject(id, OpenMode.ForRead), BlockTableRecord)
                    If btr.Name.ToUpper = BlkName.ToUpper Then
                        For Each ObjId As ObjectId In btr.GetBlockReferenceIds(False, False)
                            Dim br As BlockReference = AcTrans.GetObject(ObjId, OpenMode.ForRead)
                            If br.Name = BlkName Then
                                Dim z As Integer = 0
                                For Each obj1 As ObjectId In btr
                                    obj = AcTrans.GetObject(obj1, OpenMode.ForRead)
                                    If TypeOf obj Is AttributeDefinition Then
                                        Dim AttDef As AttributeDefinition = obj
                                        Dim AttRef As AttributeReference = CType(AcTrans.GetObject(br.AttributeCollection(z), OpenMode.ForRead), AttributeReference)
                                        If AttDef.Tag = "INITIALS" Then
                                            MsgBox("Skipping INITIALS")
                                        ElseIf AttDef.Tag = "INITIALS" = False Then
                                            taglist.Add(AttDef.Tag)
                                            txtlist.Add(AttRef.TextString)
                                            z = z + 1
                                Next
                        Next
                Next
                AcTrans.Commit()
            End Using
Replies (30)
Message 2 of 31
jabowabo
I'm not very familiar with VB.net but two equal signs in your condition looks wonky. Try changing:
to this:
ElseIf AttDef.Tag <> "INITIALS" Then
https://msdn.microsoft.com/en-us/library/cey92b0t.aspx?f=255&MSPPError=-2147217396
Message 3 of 31
fieldguy
I think what you want is this (not sure about VB syntax):
Else          <--------------  means AttDef.Tag is not = "INITIALS" - no need for "ElseIf"
taglist.Add(AttDef.Tag) txtlist.Add(AttRef.TextString) z = z + 1 End If
Message 4 of 31
_gile
If: skip a specific attribute with a tag "INITIALS" means process all attributes which tag is not "INITIALS", instead of this ugly and verbose statement:
    z = z + 1
simply do:
    z += 1
Gilles Chanteau
GileCAD
GitHub
Message 5 of 31
No go on all provided suggestions.  The attdef.tag of INITIALS is still brought forward.  That's what I don't understand because using the msgbox to test which IF is being run it runs as correct but it still grabs the INITIALS attribute.
Message 6 of 31
ActivistInvestor
Hi Ron.
In your code, I don't see the purpose of opening AttributeDefinitions at all.
The AttributeReference.TagString property holds the attribute's tag.
Message 7 of 31
_gile
Hi
Here's your code after some cleanup and optimization.
It should work if there's no type in "INITIALS".
C#
            using (var tr = db.TransactionManager.StartTransaction())
                var bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                if (bt.Has(blockName))
                    var btr = (BlockTableRecord)tr.GetObject(bt[blockName], OpenMode.ForRead);
                    foreach (ObjectId id in btr)
                        if (id.ObjectClass.DxfName == "ATTDEF")
                            var attDef = (AttributeDefinition)tr.GetObject(id, OpenMode.ForRead);
                            if (attDef.Tag != "INITIALS")
                                var attRef = (AttributeReference)tr.GetObject(br.AttributeCollection[z], OpenMode.ForRead);
                                tagList.Add(attDef.Tag);
                                textList.Add(attRef.TextString);
                tr.Commit();
VB automatic conversion with Telerik
Using tr As Transaction = db.TransactionManager.StartTransaction()
    Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
    If bt.Has(blockName) Then
	Dim btr As BlockTableRecord = DirectCast(tr.GetObject(bt(blockName), OpenMode.ForRead), BlockTableRecord)
	For Each id As ObjectId In btr
	    If id.ObjectClass.DxfName = "ATTDEF" Then
		Dim attDef As AttributeDefinition = DirectCast(tr.GetObject(id, OpenMode.ForRead), AttributeDefinition)
		If attDef.Tag <> "INITIALS" Then
		    Dim attRef As AttributeReference = DirectCast(tr.GetObject(br.AttributeCollection(z), OpenMode.ForRead), AttributeReference)
	Next
    tr.Commit()
End Using
'Service provided by Telerik (www.telerik.com)
'Conversion powered by NRefactory.
'Twitter: @telerik
'Facebook: facebook.com/telerik
Gilles Chanteau
GileCAD
GitHub
Message 8 of 31
_gile
Another little optimization: we do not know anything about 'br' and 'z', but it looks like you could open the attribute reference only once instead of  each loop.
You can also upper case the attribute definition tag before comparing it to "INITIALS"
                If attDef.Tag.ToUpper() <> "INITIALS" Then
        Next
    tr.Commit()
End Using
Gilles Chanteau
GileCAD
GitHub
Message 9 of 31
There are about 40 attributes that I'm iterating from one block to another minus the attribute with the tag INITIALS.  "br" is the blockreference, z is a list count used later.
Message 10 of 31
_gile
What I wanted to say is that as 'z' is not incremented in the For Each loop the attribute is the same every time, so it's more efficient to open it before the loop.
Anyway, did you try it? the attribute tagged "INITIALS" should be skipped, if not, it's a typo issue (case or non-printable characters) in the attribute tag.
Gilles Chanteau
GileCAD
GitHub
Message 11 of 31
I tried it.  In it you referenced br without defining it.  Working on it now.  And thank you.
Message 12 of 31
Removed reference AttRef (Attribute Reference) completely.  Works.  Thank you all for help.  Partial solution to all as I combined some suggestions that were outside the question.  Thank you all.
                Dim bt As BlockTable = DirectCast(AcTrans.GetObject(AcDb.BlockTableId, OpenMode.ForRead), BlockTable)
                If bt.Has(BlkName) Then
                    Dim btr As BlockTableRecord = DirectCast(AcTrans.GetObject(bt(BlkName), OpenMode.ForRead), BlockTableRecord)
                    'Dim attRef As AttributeReference = DirectCast(AcTrans.GetObject(br.AttributeCollection(z), OpenMode.ForRead), AttributeReference)
                            Dim attDef As AttributeDefinition = DirectCast(AcTrans.GetObject(id, OpenMode.ForRead), AttributeDefinition)
                                taglist.Add(attDef.Tag)
                                txtlist.Add(attDef.TextString)
                    Next
                AcTrans.Commit()
            End Using
Message 13 of 31
_gile
Oops!...
this one should work:
	Dim br As BlockReference = tr.GetObject(ObjId, OpenMode.ForRead)
		    z += 1
        Next
    tr.Commit()
End Using
Gilles Chanteau
GileCAD
GitHub
Message 14 of 31
**** I jumped too quick.  Without the block reference it grabs no attributes.  Back into it.
Message 15 of 31
Doesn't declare ObjID.  I think what might be missing from my explanation is that I have to first iterate through all blocks to find the specific one, then pull the attributes out of that one.  Starting with my original it does just that except it doesn't skip the attribute with the tag 'INITIALS'.
Message 16 of 31
_gile
I cannot know more about your code than what you posted in the original post (where ObjectId is not declared)...
The code I provided is just to replace the code you posted.
Gilles Chanteau
GileCAD
GitHub
Message 17 of 31
_gile
Ron_M a écrit :
I have to first iterate through all blocks to find the specific one, then pull the attributes out of that one..
No, you do not need to iterate all the block table to find a specific bloc.
SymbolTable derived types (as BlockTable) have an indexor which allows to directly get a SymbolTableRecord from uts name.
Please, attentively compare the code of your first post with the last one I provided, it exactly does the same but in a more efficient and logical way.
Gilles Chanteau
GileCAD
GitHub
Message 18 of 31
I directly copy/paste your code in and it shows error in that it doesn't define br or the block reference which leads to not having the object id.  We're getting way off track anyway.  I didn't and still don't have an issue with getting the block.  Your suggestions, and those of others, directly copied or modify does not skip the attribute when pulling lists of tags and text strings.
Message 19 of 31
_gile
Try this one (ObjId is supposed to be assign to some block reference you want to get the attribute values):
	Dim br As BlockReference = DirectCast(tr.GetObject(ObjId, OpenMode.ForRead), BlockReference)
		If System.Text.RegularExpressions.Regex.Match(attDef.Tag, "initials", RegexOptions.IgnoreCase) Then
		    MsgBox("Skipping " & attDef.Tag)
                Else
		    z += 1
        Next
Else
MsgBox("Block " & blockName & " not found.") End If tr.Commit() End Using
it would be easier for those who are trying to help you if provide some drawing with the block.
Gilles Chanteau
GileCAD
GitHub
Message 20 of 31
Attached is a test block. I need to get all text strings from the block into a list so that they can then be placed back in an updated block without the INITIALS attribute.
Your latest still takes out the ObjId which I already have. Please move past that. My original post and code works EXCEPT, and ONLY EXCEPT that it does not skip the attribute with a tag of INITIALS. That is the ONLY thing not working. The msgbox fires as it is supposed to when it hits the attribute to be skipped.  Debug shows that the msgbox fires when it is supposed to.
