Newing a drawing is missing default styles
soonhui
Advisor Advisor
soonhui
Here's my code to create a new drawing from .Net code
    [CommandMethod(nameof(CreateNewDrawing))]
    public void CreateNewDrawing()
        var fileName = @"E:\Sample Project\February 2025\EmptyDrawing.dwg";
        using var db = new Database(true, true);
        db.SaveAs(fileName, DwgVersion.Current);
I need to stress that the correct file, EmptyDrawing.dwg is created at the designated location. But when I open it, and compare it with a new drawing I create via UI, there are critical difference, in that the (Civil 3D) styles are missing.
Here are the two screenshot ( the first screenshot is for the drawing created via .Net API, the second screenshot is the drawing created via UI) that compare them:
I'm pretty sure I don't create the drawing properly via code, any command that I miss?
Ngu Soon Hui
I'm the Benevolent Dictator for Life for MiTS Software. Read more here
I also setup Civil WHIZ in order to share what I learnt about Civil 3D
_gile
new Database(true, true) constructor creates a new drawing with no template (as the _NEW command when choosing "Open with no template").
You should use new Database(false, false) and ReadDwgFile with the path of the template you want to start with.
    string fileName = @"E:\Sample Project\February 2025\EmptyDrawing.dwg";
    string templateName = "SomeTemplate.dwt";
    using var db = new Database(false, false);
    db.ReadDwgFile(templateName, FileOpenMode.OpenForReadAndAllShare, false, null);
Gilles Chanteau
GileCAD
GitHub
soonhui
@_gile , so what's the exact command that is equivalent to the New?
I guess that New command is just the above coode, plus use the template file at %localappdata%\C3D 20xx\enu\Template\_Autodesk Civil 3D (Metric) NCS.dwt, so it's just equivalent to the templateName = "%localappdata%\C3D 20xx\enu\Template\_Autodesk Civil 3D (Metric) NCS.dwt", but I don't feel like to hardcode it this way, because I don't want to change my code when I upgrade my Civil 3D version.
Is there a upgrade proof way of reading in the template file?
Ngu Soon Hui
_gile
If you're talking about the "QNEW" command, you can get the template path with:
string templatePath = HostApplicationServices.Current.GetEnvironmentVariable("QnewTemplate");
Gilles Chanteau
GileCAD
GitHub
ActivistInvestor
In the UI a template file (. dwt) is usually used as the basis for a new drawing. So you don't create a new database, instead you open a DWT file and save it as a DWG file.
