New Sample: Application-Defined System Variables
   http://www.caddzone.com/CustomSystemVariableExample.zip
Abstract:
As of AutoCAD 2010, it has been possible to add new system variables to
AutoCAD, that are both defined and managed by ObjectARX extensions
(managed or native).
Application-defined system variables behave just like AutoCAD's
own 'built-in' system variables.
The sample project at the above link shows how to implement your own
application-defined system variables.
kerry_w_brown
Thank you Tony.
Interesting concept with a lot of potential.
... and a generous license.
also excellent study material.
// Called Kerry or kdub in my other life.
Everything will work just as you expect it to, unless your expectations are incorrect. ~ kdub
Sometimes the question is more important than the answer. ~ kdub
NZST UTC+12 : class keyThumper<T> : Lazy<T>;      another  Swamper
Hope this is a tease to book or guide you are putting together
Well, it woudln't make sense to just throw it out there if that were the case, as I haven't really left much out.
Sorry, what I meant was the example was great. It had a good explantion and good design pattern,reusable, easy to matain etc...... all of the things you try to accomplish writing code.
I was implying it would great to have a book that covered many topics in the API like your example.
Sorry about that.
I didn't bother checking the 2010 API, and just learned that the APIs
required to implement app-defined sysvars is not avaialble in 2010.
A revised and expanded version of the sample has been posted at
the same URL, which makes that clear.
