new database, readdwgfile, insunits
fieldguy
Advisor Advisor
fieldguy
I am using this code to rename dwg files from a third party.  The insunits are set to "2" (feet).  I thought I could change the units at the same time, but it is not working.
We work in metres (insunits = "6").
string dwgname = "dwg from third party";
string newname = "newname.dwg";
string savepath = "c:\\temp\\";
using (Database db = new Database(false, true)) { db.ReadDwgFile(dwgname, FileOpenMode.OpenForReadAndWriteNoShare, false, ""); db.CloseInput(true); using (Transaction tr = db.TransactionManager.StartTransaction()) { Application.SetSystemVariable("INSUNITS", 6); tr.Commit(); }// using tr db.SaveAs(savepath + newname, DwgVersion.Current);
}// using new database
What is the correct procedure?
fieldguy
The answer is  replace "Application.SetSystemVariable("INSUNITS", 6)" with "db.Insunits = acdb.UnitsValue.Meters;"
I should have searched a bit further.
_gile
Try doing simply like this:
            using (var db = new Database(false, true))
                db.ReadDwgFile(dwgname, FileOpenMode.OpenForReadAndAllShare, false, "");
                db.Insunits = UnitsValue.Meters;
Gilles Chanteau
GileCAD
GitHub
fieldguy
Yes - thanks.  It occurred to me (too late) that I didn't need a transaction to set an application system variable.
In my own words - "SEARCH FIRST" and use the correct search parameters.
