In AutoCAD 2010, I would issue the "netload" command, browse to a local folder and pick the .dll, then "OK". I could then enter the command that would run the program.
I now have 2015 installed on my computer and I try to do the same thing. I run the netload command, browse, and pick the same .dll, but when I enter the command to run the program, it says "Unknown command"
Is there some new setting I need to set?
BTW, I've also looked at "Unblock" but the .dll does not have a warning in it's Properties dialog and it's copied local.
Mark
