.NET Framework 4.8
.NET Framework 4.8
gleeuwdrent
.NET Framework 4.8
gleeuwdrent
Hi all, since .NET Framework 4.8 is the standard framework for VS 2022, is it possible to upgrade existing plugins (.NET Framework 4.7.2) to 4.8 without any problems? Will the plugins work also for older AutoCAD versions? Or do I need to stay at 4.7.2?
_gile
The only problem is that the Framework 4.8 is not installed on the end user's computer.
Yes, it will.
You can keep your projects targeting older Frameworks as long as you don't use the features of newer Frameworks (in this case Visual Studio won't compile the project).
Gilles Chanteau
GileCAD
GitHub
gleeuwdrent
Thanks for your reply, clear now.
sivaprasad.yarlagadda2016
After upgrading existing plugins in Visual studio 2022 with .Net framework  getting below error .Please suggest.
 'Autodesk.Map.IM.Forms.Desktop.DocumentFlyIn' could not be loaded. Ensure the assembly has been referenced and that all projects have been built in AutoCAD Map3D 2024 and Visual studio 2022.
