[.net api] " LinearArray" and "RadialArray" method
sapch
sapch
Is there an "LinearArray" and "RadialArray"  method for AS? Like Revit API:
static LinearArray Create(Document aDoc, View dBView, ElementId id, int count, XYZ translationToAnchorMember, ArrayAnchorMember anchorMember);
static RadialArray Create(Document aDoc, View dBView, ElementId id, int count, Line axis, double angle, ArrayAnchorMember anchorMember);
norman.yuan
@sapch wrote:
...  method for AS? ...
What is "AS", are you posting in wrong forum (this is for .NET API for plain AutoCAD, but questions on AutoCAD verticals may appear from time to time)?
Norman Yuan
Drive CAD With Code
Alexander.Rivilis
Try this sample:
using System;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.Geometry;
using Autodesk.AutoCAD.EditorInput;
// This line is not mandatory, but improves loading performances
[assembly: CommandClass(typeof(ArrayClassic.MyCommands))]
namespace ArrayClassic
  public class MyCommands
    // Использование: Создание Прямоугольного Ассоциативного Массива
    [CommandMethod("CreateAssocArrayRect")]
    public void CreateAssocArrayRect()
      Document doc = Application.DocumentManager.MdiActiveDocument;
      Database db = doc.Database;
      Editor ed = doc.Editor;
      int nRows = 5;
      int nColumns = 5;
      double dRowOffset = 1;
      double dColumnOffset = 1;
      using (Transaction Tx = db.TransactionManager.StartTransaction())
        // Создаем исходный примитив - здесь простой круг (Circle)
        Circle circle = new Circle(new Point3d(2, 2, 0), new Vector3d(0, 0, 1), 0.5);
        circle.ColorIndex = 1;
        ObjectIdCollection sourceEntities = new ObjectIdCollection();
        // Исходный примитив должен быть в базе
        AcHelper.PostToDatabase(circle);
        sourceEntities.Add(circle.ObjectId);
        // Базовая точка массива в  VertexRef
        VertexRef basePoint = new VertexRef(new Point3d(2, 2, 0));
        // Параметры прямоугольного массива
        double columnSpacing = dRowOffset;
        double rowSpacing = dColumnOffset;
        double levelSpacing = dColumnOffset;
        int columnCount = 5;
        int rowCount = 5;
        int levelCount = 1;
        double rowElevation = 0;
        double axesAngle = 0;
        Matrix3d curUCSMatrix = ed.CurrentUserCoordinateSystem;
        CoordinateSystem3d curUCS = curUCSMatrix.CoordinateSystem3d;
        Vector2d acVec2dAng = new Vector2d(curUCS.Xaxis.X, curUCS.Xaxis.Y);
        axesAngle += acVec2dAng.Angle;
        AssocArrayRectangularParameters parameters = new AssocArrayRectangularParameters(columnSpacing,
            rowSpacing,
            levelSpacing,
            columnCount,
            rowCount,
            levelCount,
            rowElevation,
            axesAngle);
        parameters.AxesAngle = acVec2dAng.Angle;
        parameters.XAxisDirection = curUCS.Xaxis;
        parameters.YAxisDirection = curUCS.Yaxis;
        // Как показано ниже, параметры могут быть связаны с выражениями, включающими переменные
        AcHelper.AddOrModifVariable("RowCount", rowCount.ToString());
        AcHelper.AddOrModifVariable("RowSpacing", rowSpacing.ToString());
        parameters.SetRowCount(rowCount, "RowCount", "");
        parameters.SetRowSpacing(rowSpacing, "RowSpacing", "");
        // Создаем массив. Возвращается AssocArray помещенный в базу
        AssocArray array = Autodesk.AutoCAD.DatabaseServices.AssocArray.CreateArray(sourceEntities,
            basePoint,
            parameters);
        // Если нужно переместить массив, то имея его свойство EntityId
        // можно применить трансформацию как показано ниже
        Entity arrayEnt = Tx.GetObject(array.EntityId, OpenMode.ForWrite) as Entity;
        arrayEnt.TransformBy(Matrix3d.Displacement(new Vector3d(5, 5, 5)));
        // Заставляем обновится все связи
        AssocManager.EvaluateTopLevelNetwork(db, null, 0);
        // Так как массив уже создан, то исходный круг можно удалить.
        // Он уже содержится в массиве (фактически в анонимном блоке)
        circle.Erase(true);
        Tx.Commit();
  public class AcHelper
    // Helper method: Добавление примитива в пространство модели указанной базы данных
    public static ObjectId PostToDatabase(Database db, Entity entity)
        BlockTable bt = Tx.GetObject(db.BlockTableId, OpenMode.ForRead) as BlockTable;
        BlockTableRecord model = Tx.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForWrite) as BlockTableRecord;
        ObjectId newId = model.AppendEntity(entity);
        Tx.AddNewlyCreatedDBObject(entity, true);
        Tx.Commit();
        return newId;
    // Helper method: Добавление примитива в пространство модели текущей базы данных
    public static ObjectId PostToDatabase(Entity entity)
      Database db = Application.DocumentManager.MdiActiveDocument.Database;
      return PostToDatabase(db, entity);
    // Добавление новой переменной в ассоциативную сеть или модификация существующей
    public static ObjectId AddOrModifVariable(string varName, string varExpression)
      ObjectId varid = ObjectId.Null;
        ObjectId networkId = AssocNetwork.GetInstanceFromObject(db.CurrentSpaceId, true, true, "ACAD_ASSOCNETWORK");
        AssocNetwork network = Tx.GetObject(networkId, OpenMode.ForWrite) as AssocNetwork;
        ObjectIdCollection actionIds = network.GetActions;
        for (int i = 0; i < actionIds.Count; ++i)
          try
            AssocVariable var1 = Tx.GetObject(actionIds[i], OpenMode.ForWrite) as AssocVariable;
            if (var1 != null)
              if (var1.Name == varName)
                String errMsg = "";
                var1.SetExpression(varExpression, "", true, true, ref errMsg, false);
                ResultBuffer rb = new ResultBuffer();
                errMsg = var1.EvaluateExpression(ref rb);
                var1.Value = rb;
                Tx.Commit();
                return var1.ObjectId;
          catch
        AssocVariable var = new AssocVariable();
        varid = network.Database.AddDBObject(var);
        network.AddAction(var.ObjectId, true);
        Tx.AddNewlyCreatedDBObject(var, true);
        Tx.Commit();
        AssocVariable var = (AssocVariable)Tx.GetObject(varid, OpenMode.ForWrite);
        var.SetName(varName, true);
        var.Value = new ResultBuffer(new TypedValue(1001, 5));
        String errMsg = "";
        var.SetExpression(varExpression, "", true, true, ref errMsg, false);
        errMsg = var.EvaluateExpression(ref rb);
        var.Value = rb;
        Tx.Commit();
      return varid;
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
