Need Help in using saveas function to save thumbnail image
    Now I am facing a problem,I use database.SaveAs function to save a dwg file,but the dwg file do not have an thumbnail image,so I trid to search kean's blog ,and I write code like below,but I can't get what I want.
[CommandMethod("SendSaveAsCmd", CommandFlags.Session)]
        public static void DoSaveAs()
            string filepath = @"C:\Users\FL_DRAWING\Desktop\Images\1.dwg";
            string targetpath = @"C:\Users\FL_DRAWING\Desktop\Images\newdwg.dwg";
            Document doc = Application.DocumentManager.Open(filepath, false);
            doc.LockDocument();
            Database db = doc.Database;
            object ocmd = Application.GetSystemVariable("CMDECHO");
            string newpath = targetpath.Replace("\\", "/");
            string cmd =
                "(setvar \"CMDECHO\" 0)" +
                "(command \"_.SAVEAS\" \"\" \"" + newpath + "\")" +
                "(setvar \"CMDECHO\" " + ocmd.ToString() + ")" +
                "(princ) ";
            doc.SendStringToExecute(cmd,false,false,false);
            doc.CloseAndDiscard();
And I tried Another way like below
[CommandMethod("SaveThumbnail", CommandFlags.Session)]
        public static void DoSaveThumbnail()
            Document doc = Application.DocumentManager.Open(filepath);
            doc.LockDocument();
            db.RetainOriginalThumbnailBitmap = true;
            Bitmap thumb = db.ThumbnailBitmap;
            db.ThumbnailBitmap = thumb;
            db.SaveAs(targetpath, DwgVersion.Current);
But the thumb is null in line Bitmap thumb = db.ThumbnailBitmap
In one of kean's blog ,I saw Document.CapturePreviewImage
So I rewrite my code like below
            doc.LockDocument();
            Bitmap thumb = doc.CapturePreviewImage(320, 240);
And I get a thumbnail image with a black background, but the thumbnail could not fullfill the thumbnail in Windows document viewer.And I also could not see cleer in Windows Document viewer.
Any help will be great, thank you.
Virupaksha_aithal
Autodesk Support
Autodesk Support
Try passing true for “bBakAndRename” in saveas API like
db.SaveAs(str, true, DwgVersion.Current, db.SecurityParameters); along with RetainOriginalThumbnailBitmap
Refer http://forums.autodesk.com/t5/net/retainoriginalthumbnailbitmap-not-working-for-replacing-the/td-p/6...
Virupaksha Aithal KM
Developer Technical Services
Autodesk Developer Network
Hi,First I want to thank u for reply and I tried ur way but there is still another problem I try to build plenty of dwgs which has no thumbnail image,
if the dwg file has an thumbnail I use your method ,the anwser is yes,and I got a new dwg file with thumbnail,
but if the diw file has no thumbnail,and I tried,there is a dwg file I get without thumbnail.
Hope I am wrong and wish ur another anwser,thank u
