multiple layout export to separate CAD files using c#
Ahmed_204
Message 1 of 9
Ahmed_204
Hi All,
I am trying to run the below code which I got from theswamp.org website but its not working, kindly can anyone  highlight the issue and try to solve it.
EXPORTLAYOUTS command example (theswamp.org)
[CommandMethod("EXPORTLAYOUTS")]
public static void ExportLayoutsCommand()
var doc = Application.DocumentManager.MdiActiveDocument;
var db = doc.Database;
var editor = doc.Editor;
try
// check if drawing saved or not
if ((short)Application.GetSystemVariable("DWGTITLED") == 0)
editor.WriteMessage("\nCommand cannot be used on an unnamed drawing");
return;
string format =Path.Combine(Path.GetDirectoryName(doc.Name),Path.GetFileNameWithoutExtension(doc.Name))+ "_{0}.dwg";
editor.WriteMessage(format);
string[] names = null;
using (Transaction tr = doc.TransactionManager.StartTransaction())
// Get the localized name of the model tab:
BlockTableRecord btr = SymbolUtilityServices.GetBlockModelSpaceId(db).GetObject(OpenMode.ForRead) as BlockTableRecord;
Layout layout = btr.LayoutId.GetObject(OpenMode.ForRead) as Layout;
string model = layout.LayoutName;
// Open the Layout dictionary:
IDictionary layouts = db.LayoutDictionaryId.GetObject(OpenMode.ForRead) as IDictionary;
// Get the names and ids of all paper space layouts into a list:
names = layouts.Keys.Cast<string>().Where(name => name != model).ToArray();
tr.Commit();
int cmdecho = 0;
#if DEBUG
cmdecho = 1;
#endif
using (new ManagedSystemVariable("CMDECHO", cmdecho))
using (new ManagedSystemVariable("CMDDIA", 0))
using (new ManagedSystemVariable("FILEDIA", 0))
using (new ManagedSystemVariable("CTAB"))
foreach (string name in names)
string filename = string.Format(format, name);
editor.WriteMessage("\nExporting {0}\n", filename);
Application.SetSystemVariable("CTAB", name);
editor.Command("._EXPORTLAYOUT", filename);
public static class EditorInputExtensionMethods
public static PromptStatus Command(this Editor editor, params object[] args)
if (editor == null)throw new ArgumentNullException("editor");
return runCommand(editor, args);
static Func<Editor, object[], PromptStatus> runCommand = GenerateRunCommand();
static Func<Editor, object[], PromptStatus> GenerateRunCommand()
MethodInfo method = typeof(Editor).GetMethod("RunCommand",
BindingFlags.Instance | BindingFlags.NonPublic | BindingFlags.Public);
var instance = Expression.Parameter(typeof(Editor), "instance");
var args = Expression.Parameter(typeof(object[]), "args");
return Expression.Lambda<Func<Editor, object[], PromptStatus>>(Expression.Call(instance, method, args), instance, args).Compile();
/// <summary>
/// Automates saving/changing/restoring system variables
/// </summary>
public class ManagedSystemVariable : IDisposable
string name /*= null*/;
object oldval /*= null*/;
public ManagedSystemVariable(string name, object value): this(name)
Application.SetSystemVariable(name, value);
public ManagedSystemVariable(string name)
if (string.IsNullOrWhiteSpace(name))throw new ArgumentException("name");
this.name = name;
this.oldval = Application.GetSystemVariable(name);
public void Dispose()
if (oldval != null)
object temp = oldval;
oldval = null;
Application.SetSystemVariable(name, temp);
catch (System.Exception ex)
#if DEBUG
editor.WriteMessage(ex.ToString());
#else
throw ex;
#endif
Replies (8)
Message 2 of 9
essam-salah
Hi @Ahmed_204
i tested EXPORTLAYOUTS2 and it works fine, what errors did you get?
using System;
using System.Collections;
using System.Collections.Generic;
using System.IO;
using System.Linq;
using System.Reflection;
using System.Linq.Expressions;
using Autodesk.AutoCAD.ApplicationServices;
using Autodesk.AutoCAD.DatabaseServices;
using Autodesk.AutoCAD.EditorInput;
using Autodesk.AutoCAD.Runtime;
// requires a reference to AcExportLayout.dll:
using AcExportLayout = Autodesk.AutoCAD.ExportLayout;
namespace ClassLibrary1
    public static class ExportLayoutsCommands
        /// <summary>
        /// Automates the EXPORTLAYOUT command to export
        /// all paper space layouts to .DWG files.
        /// In this example, we export each layout to
        /// a drawing file in the same location as the
        /// current drawing, wherein each file has the
        /// name "<dwgname>_<layoutname>.dwg".
        /// This is not a functionally-complete example:
        /// No checking is done to see if any of the
        /// files already exist, and existing files
        /// are overwritten without warning or error.
        /// No checking is done to detect if an existing
        /// file exists and is in-use by another user, or
        /// cannot be overwritten for any other reason.
        /// No checking is done to ensure that the user
        /// has sufficient rights to write files in the
        /// target location.
        /// You can and should deal with any or all of
        /// the above as per your own requirements.
        /// </summary>
        /// <summary>
        /// Doesn't use the command line, requires AutoCAD R12
        /// or later and a reference to AcExportLayout.dll:
        /// This version can be used from the application context,
        /// which can make it easier to use in a batch process that
        /// exports layouts of many files.
        /// The example also shows how to use the AcExportLayout
        /// component to export a layout to an in-memory Database
        /// without creating a drawing file.
        /// </summary>
        [CommandMethod("EXPORTLAYOUTS2", CommandFlags.Session)]
        public static void ExportLayouts2()
            try
                    return;
                string format =
                   Path.Combine(
                   + "_{0}.dwg";
                Dictionary<string, ObjectId> layouts = null;
                using (doc.LockDocument())
                        BlockTableRecord btr = (BlockTableRecord)
                              .GetObject(OpenMode.ForRead);
                        Layout layout = (Layout)
                           btr.LayoutId.GetObject(OpenMode.ForRead);
                        IDictionary layoutDictionary = (IDictionary)
                           db.LayoutDictionaryId.GetObject(OpenMode.ForRead);
                        // into a Dictionary<string,ObjectId>:
                        layouts = layoutDictionary.Cast<DictionaryEntry>()
                           .Where(e => ((string)e.Key) != model)
                           .ToDictionary(
                              e => (string)e.Key,
                              e => (ObjectId)e.Value);
                        tr.Commit();
                    /// Get the export layout 'engine':
                    Autodesk.AutoCAD.ExportLayout.Engine engine =
                       Autodesk.AutoCAD.ExportLayout.Engine.Instance();
                        foreach (var entry in layouts)
                            string filename = string.Format(format, entry.Key);
                            editor.WriteMessage("\nExporting {0} => {1}\n", entry.Key, filename);
                            Application.SetSystemVariable("CTAB", entry.Key);
                            using (Database database = engine.ExportLayout(entry.Value))
                                if (engine.EngineStatus == AcExportLayout.ErrorStatus.Succeeded)
                                    database.SaveAs(filename, DwgVersion.Newest);
                                else
                                    editor.WriteMessage("\nExportLayout failed: ",
                                       engine.EngineStatus.ToString());
                                    break;
#if DEBUG
            editor.WriteMessage( ex.ToString() );
#else
                throw ex;
#endif
    /// <summary>
    /// </summary>
        string name = null;
        object oldval = null;
           : this(name)
            this.name = name;
            if (oldval != null)
                oldval = null;
Message 3 of 9
essam-salah
@Ahmed_204
you have to reference AcExportLayout.dll you found it in the same location of acdbmgd.dll.
Message 4 of 9
Ahmed_204
Hi @essam-salah ,
After I referenced AcExportLayout.dll , Exportlayout2 worked fine but my issue now while trying to use EXPORTLAYOUTS I am receiving the below error.
._EXPORTLAYOUT Autodesk.AutoCAD.Runtime.Exception: eInvalidInput
at Autodesk.AutoCAD.ApplicationServices.Core.Application.SetSystemVariable(String name, Object value)
at Export_Layout.ManagedSystemVariable.Dispose() in H:\AutoCAD Building Add-ins with C#_LinkedIn Course\My Autocad Projects\Export Layouts\Export_Layout\myCommands.cs:line 356
at Export_Layout.MyCommands.ExportLayoutsCommand() in H:\AutoCAD Building Add-ins with C#_LinkedIn Course\My Autocad Projects\Export Layouts\Export_Layout\myCommands.cs:line 141
Thanks for your support.
Message 5 of 9
essam-salah
@Ahmed_204
yes it gives the same error, and the problem is in line editor.Command("._EXPORTLAYOUT", filename);
and i think it's a common problem in autocad sending comman with parameters.
Message 6 of 9
Ahmed_204
Hi @_gile ,
Do you know any possible solution for the above error ?
Message 7 of 9
Chuong.Ho
Any has ideal for this error ? Thanks you
Chuong Ho
Message 8 of 9
@Ahmed_204 wrote:
Hi All,
I am trying to run the below code which I got from theswamp.org website but its not working, kindly can anyone  highlight the issue and try to 밤알바 solve it.
try
return;
tr.Commit();
int cmdecho = 0;
#if DEBUG
cmdecho = 1;
#endif
/// <summary>
/// </summary>
this.name = name;
if (oldval != null)
oldval = null;
#if DEBUG
#else
throw ex;
#endif
I was facing the same issue could you please let me know which solution you have found and what is the best one?actually i also facing the same issue.
Message 9 of 9
Chuong.Ho
I have spent several weeks researching it and there is no solution to this problem
Chuong Ho
