MText Unable to update
Hi Team,
Unable to update Mtext please find below code.
Note: Please advice me there is any way to debug command code .
	[CommandMethod("MyTestCommands", "test", CommandFlags.Modal)]
        public void Test()
            var doc = Application.DocumentManager.MdiActiveDocument;
            var ed = doc.Editor;
            var res1 = ed.GetFileNameForOpen("Specify parameter file");
            if (res1.Status != Autodesk.AutoCAD.EditorInput.PromptStatus.OK)
                return;
            var res2 = ed.GetString("Specify output sub-folder name");
            if (res2.Status != Autodesk.AutoCAD.EditorInput.PromptStatus.OK)
                return;
            try
                var db = doc.Database;
                using (Transaction tr = db.TransactionManager.StartTransaction())
                    BlockTableRecord btr = (BlockTableRecord)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
                    foreach (ObjectId id in btr)
                        Entity currentEntity = tr.GetObject(id, OpenMode.ForWrite, false) as Entity;
                        if (currentEntity == null)
                            continue;
                        if (currentEntity.GetType() == typeof(MText))
                            ((MText)currentEntity).Contents = "BlahBlah";
                        else
                            ((DBText)currentEntity).TextString = "BlahBlah";
                    tr.Commit();
            catch (System.Exception e)
                using (var writer = File.CreateText(Path.Combine(res2.StringResult, "error.txt")))
                    writer.WriteLine(e.ToString());
                ed.WriteMessage("Error: {0}", e.ToString());
_gile
There're some mistakes in your code.
db.BlockTableId is the ID of the database block table which type is BlockTable, not a BlockTableRecord
Assuming you want to get the model space block table record, you can do it this way:
var bt = (BlockTable)tr.GetObject(db.BlockTableId, OpenMode.ForRead);
var btr = (BlockTableRecord)tr.GetObject(bt[BlockTableRecord.ModelSpace], OpenMode.ForRead);
or, using SymbolUtilityServices as in the above code.
While iterating the model space entities you cast all entities which are not MText into DBText, this will throw an error with any entity which does not derive from DBText.
Here's a little example on how to achieve what you're trying to do:
        public void Test()
                return;
                return;
            try
                    // open the model space block table record for read
                        SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead);
                    var textClass = RXObject.GetClass(typeof(DBText));
                    var mtextClass = RXObject.GetClass(typeof(MText));
                        // if this is the ID of a DBText
                        if (id.ObjectClass.IsDerivedFrom(textClass))
                            var text = (DBText)tr.GetObject(id, OpenMode.ForWrite);
                            text.TextString = "BlahBlah";
                        // if this is the ID of a MText
                        else if (id.ObjectClass.IsDerivedFrom(mtextClass))
                            var mtext = (MText)tr.GetObject(id, OpenMode.ForWrite);
                            mtext.Contents = "BlahBlah";
                    tr.Commit();
Gilles Chanteau
GileCAD
GitHub
_gile
You should display the Exception.StackTrace to have more details on the exception
 try
    ed.WriteMessage("\nError: {0}\n{1}", e.Message, e.StackTrace);
You can also use break points in you code, and run it step by step in debug mode.
Gilles Chanteau
GileCAD
GitHub
Hi Gilles Chanteau,
Thank you for your replay. My source file text not changing.
am doing below process.
1. Create command dll as zip
2. upload zip and create new package in autodesk design automation API.
3.and creating Activity in design automation API.
4. submitting work item.
5. download the source file from autodesk cloud
as given solution changes  not affecting the source file.
Ragunath.s
