If by "DBText" [is that a .net API term?] you mean what a lot of people often refer to as "DTEXT," be aware that in AutoCAD there is no such entity type -- it's just TEXT.
If any of your labels will need more than one line, Mtext will do that in one object [that's what the M is for], whereas with Text you would need a separate object for each line.
For single-line content, Text uses less memory than Mtext.
If you would ever need to include stacked fractions, Text can't do that [unless you have a font with special characters defined for some of those], so you would need to use Mtext.
Text can be given a width factor and/or an obliquing angle, neither of which you can do with Mtext except for the limited obliquing of italics, but a) that can only be used with .ttf fonts [not .shx fonts -- Text can oblique either], and b) you have no say in the degree of obliquing [with Text, you can tilt it to any angle you want].
Mtext can be made Bold or not within the use of the same [.ttf only] font, whereas Text [of whichever font type] requires either a bolder font or [in .shx fonts] a different lineweight.
With Mtext, you can change properties of portions of the same object separately from the rest [height, italics, bold, color, even the font], whereas all those characteristics [and also width factor] apply to the entirety of a Text object. So with Mtext, you can [for instance] have a room label in a floor plan that has the room name larger and bolder, and its square footage smaller and lighter, and its occupant's name different from either of those [and italic, or whatever], and a room number, and so on, all in one object.
Text has both Middle and Middle Center justification options, as well as Left and Bottom Left, Center and Bottom Center, and Right and Bottom Right, which have different effects depending on whether the content has characters that extend [for the Middle versions} above or below the nominal height, or [for the Bottom versions] below the baseline. Mtext has only the two-word versions of all those, so [for instance] you can't have the insertion-point bottom of an Mtext object on the baseline of the bottom line of text if it has any descenders, and if you change its content, it can shift position without its insertion point having been moved.
Text also has the Align and Fit options that have no corollary at all in Mtext.
Mtext has a certain amount of word-processing-like capability [e.g. tabs].
There are probably a few other things....
Kent Cooper, AIA
