Missing regen after editing a block definition, or after its undo
stefanome
stefanome
I have a command that changes the definition of a block.
After executing the command, the already existing instance of the block doesn't show the update until a REGEN is executed.
I have added Editor.Regen() at the end of the function, right after it has finished updating the block definition, and now I see the updated block.
The problem is that if, after executing the command, I undo, the block definition goes back to its previous condition, but the existing instance doesn't show the update until a manual REGEN. Again, the undo doesn't know that a REGEN is required.
The command already has the CommandFlags.Redraw flag.
Is adding the Editor.Regen() the correct solution?
If yes, how do I make sure the block is regenerated after undo?
ActivistInvestor
Autodesk.AutoCAD.Internal.CoreUtils.SetUndoRequiresRegen(Darabase db)
stefanome
Thank you, that's exactly what I need!
It's a little scary that searching for it in the whole autodesk.com doesn't find any matches: https://www.google.com/search?q=site%3Aautodesk.com+SetUndoRequiresRegen
Where and how did you find this function?
ActivistInvestor
It is an undocumented API that was intended for internal use only. The primary means of discovering this kind of stuff is by using a decompiler/disassembler like IlSpy
stefanome
I'm not decompiler ready yet!
For the time being I'm happy that you gave me the correct solution.
And I'm happy that I wasn't missing some obvious piece of documentation.
