Method to allow user to place block instance after importing block?
I've implemented a method that lets users import a cad, .dwg, file from a part library plugin. After the import the file is imported as a block - would it be possible to then show the user the block for placement similar to how you get a thumbnail over the mouse when placing a block through the interface when using INSERT?
Thank you for any suggestions.
fieldguy
search the forum for "blockjig".  >>example<<
Thank you very much for the tip fieldguy!
I've implemented a method which grabs the inserted block and throws it into a Jig for user placement!
muito bom
