MDI Active Document isActive = False
Message 1 of 19
Hello
I am developing a code that opens a dwg file,draw something and then close it
then i need to draw something on Active MDI (which was the active before I open the file) but it's IsActive Variable is not set to true?
How can I fix this
Replies (18)
Message 2 of 19
Paulio
Could you provide some code showing what you have so far?
It might be easier to help if we can see what you're doing...
Message 3 of 19
zcBlockDoc = zcDocMngr.Open(BlockPath, True)
zcDocMngr.MdiActiveDocument = zcBlockDoc
With zcBlockDoc
.Database.SaveAs(_RandomName, DwgVersion.Current) ', False)
.CloseAndDiscard()
End With
zcBlockDoc.Dispose()
ZwSoft.ZwCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument = zcOriginalDoc
This is a snap from the code (it's a long one) ...I need to set the MDIActiveDocument to another file and activate it as in debug mode the property IsActive of MDIActiveDocument is set to flase
Message 4 of 19
Paulio
It's going to be difficult to help without knowing what's going on in your zc and Zw classes.
Is this run from a command with CommandFlags.Session?
Message 5 of 19
yes I did that
<CommandMethod("SMR", CommandFlags.Session)>
Public Sub SmartInsert()
...Code Mentioned above
End Sub
Message 6 of 19
    Friend zcOriginalDoc As Document = Application.DocumentManager.MdiActiveDocument
            Application.SetSystemVariable("SDI", 0)
            Application.SetSystemVariable("attdia", 1)
            Application.SetSystemVariable("cmdecho", 0)
            Dim OpenDwgFileDialog As New System.Windows.Forms.OpenFileDialog()
            With OpenDwgFileDialog
                .InitialDirectory = EdrivePath
                .Filter = "E-drive Block Files |*.Dwg"
                .Title = "Select an E-drive Block File....."
                .FileName = ""
                .RestoreDirectory = True
            End With
            If OpenDwgFileDialog.ShowDialog = System.Windows.Forms.DialogResult.OK Then
                FullEdriveFileName = OpenDwgFileDialog.FileName.ToUpper
zcBlockDoc = zcDocMngr.Open(FullEdriveFileName, True)
zcBlockDoc = ZwSoft.ZwCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument
            Else
                OpenDwgFileDialog.Dispose()
            End If
        End Sub
Then we perfume some operations on the file and close it and set the MDI Active document back to the original file
        With zcBlockDoc
            .CloseAndDiscard()
        End With
The problem appears when trying to insert the zcBlockDoc document as a block in the zcOriginalDoc
In the blow code as the .net environment always finds the zcOriginalDoc Not active
        Dim zcInsPntRes As PromptPointResult
        Dim zcInsPntOpts As PromptPointOptions = New PromptPointOptions("")
        With zcInsPntOpts
            .UseBasePoint = False
            .Message = vbCrLf & "Specify the insertion point for block :"
        End With
         zcInsPntRes = zcOriginalDoc.Editor.GetPoint(zcInsPntOpts)
Message 7 of 19
Paulio
So you're trying to insert a drawing as a block? If that's the case then there are almost certainly examples of how to do that on this forum.
If I'm missing something and you can't use those other methods for whatever reason, then these two lines look a bit suspect to me:
Message 8 of 19
This line I am using to open the block file to do some operations on it
 here I am just setting the block file to be the current active document
Message 9 of 19
Ok after closing the block file
I need to set the MDIActivedocument to be the original file.. how?
Message 10 of 19
Paulio
Sorry, I'm not really understanding the problem. If you have a drawing open and you then open another, when you close that other drawing, the original one becomes current automatically, no?
Can you not just get the activedocument again after closing the one you opened rather than storing it up front and trying to reuse that?
Message 11 of 19
yes this is the problem the original drawing doesn't become the current automatically...I wish to do that and then
get a point to insert the block from original drawing
Message 12 of 19
Paulio
So what do you get if you try to get the active document right before you try to get the point? Are you saying that the activedocument is null?
Message 13 of 19
einvalid input
.EditorInput.PromptEditorOptions.InitGet()
.EditorInput.PromptPointOptions.DoIt()
.EditorInput.Editor.DoPrompt(PromptOptions opt)
Message 14 of 19
Paulio
Sorry, I meant what does the call to MDIActiveDocument give you back?
e.g. Document doc = Application.DocumentManager.MDIActiveDocument.
What is doc at this point? Null?
Message 15 of 19
No it's not null...it's the document but I still can't get a point on it as it IaActive property is false?
Message 16 of 19
I need to reset the original document to active?
Message 17 of 19
Paulio
OK, so you're saying this line:
is failing, yes?
Forgive me if I'm repeating myself, but have you tried
zcInsPntRes = Application.DocumentManager.MDIActiveDocument.Editor.GetPoint(zcInsPntOpts)
Message 18 of 19
yes I have tried this
 and It's Also failing
Message 19 of 19
Paulio
This works for me. It opens a drawing, saves it out to a different name and then asks the user to specify a point.
        [CommandMethod("TestMethod", CommandFlags.Session)]
        public void TestMethod()
            // Open a file
            Document newDoc = Application.DocumentManager.Open(@"C:\Temp\testDrawing.dwg", false, string.Empty);
            newDoc.Database.SaveAs(@"C:\Temp\testDrawingRenamed.dwg", Autodesk.AutoCAD.DatabaseServices.DwgVersion.Current);
            newDoc.CloseAndDiscard();
            PromptPointOptions pOpts = new PromptPointOptions(string.Empty);
            pOpts.UseBasePoint = false;
            pOpts.Message = "\nSpecify the insertion point for the block :";
            Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            PromptPointResult res = ed.GetPoint(pOpts);
            ed.WriteMessage($"\n{res.Value.X},{res.Value.Y}");
Result:
