Loop for Getpoint in a WPF Modal form
s_velasquez
Message 1 of 11
s_velasquez
I need to create a loop for inserting blocks from a WPF MODAL form.
But I'm not getting it with my code using PromptPointOptions, I have a Flash of the form every time I enter a point.
How can I fix my code?
// This is the code that displays the modal form
public class Commands
    [CommandMethod("ModalForm")]
    public static void ModalForm()
        var dialog = new WpfModalForm();
        // carrega o formulario
        var result = AcAp.ShowModalWindow(AcAp.MainWindow.Handle, dialog, false);
// This is the code for the button that asks you to select points
private void OkButtonName_Click(object sender, RoutedEventArgs e)
      var ed = AcAp.DocumentManager.MdiActiveDocument.Editor;
      var ppo = new PromptPointOptions("\nSpecify insertion point: ");
      ppo.AllowNone = true; // allows a null value
      while (true)
          var ppr = ed.GetPoint(ppo);
          if (ppr.Status == PromptStatus.OK)
              ed.WriteMessage("\nInsert and process the block at the point: " + ppr.Value.ToString());
          else
              ed.WriteMessage("\nNo points specified, the form will be reopened");
              break;
Accepted solutions (3)
Replies (10)
Message 2 of 11
norman.yuan
When a modal form (dialog box) is shown, in order to hide the form for user to interact with the Editor (picking point, in your case) and then back to the modal form, you call Editor.StartUserInteraction(), which hide the form and then shows it back:
      using (ed.StartUserInteraction(this))
         while (true)
           else
              break;
Norman Yuan
Drive CAD With Code
Message 3 of 11
_gile
You can try using Editor.StartUserInteraction method.
private void Button_Click(object sender, RoutedEventArgs e)
        while (true)
            else
                break;
Gilles Chanteau
GileCAD
GitHub
Message 4 of 11
s_velasquez
Thanks to Norman and Gile for the response.
Using Editor.StartUserInteraction method solved my problem.
Message 5 of 11
s_velasquez
Does anyone know of a way to use 'using '(ed.StartUserInteraction(...)' or something similar in a class or static method?
Message 6 of 11
norman.yuan
I assume that you want to place the code of user interacting with Editor (e.g. calling Editor.GetXxxx() in a shared utility class as static methods and then call these static methods in the UI's code behind (yes, that is good practice of separating CAD dealing code with UI code).
You can wrap your static methods, which call Editor.GetXxx() inside, with overloaded method that accepts either IWin32Window (for Win Form UI), or System.Windows.Window (for WPF UI) as input. Something like:
public static Point3d? SelectPointInMdiDocument(Editor ed)
  var res=ed.GetPoint("\nSelect point:");
  if (res.Status==PromptStatus.OK)
    return res.Value;
  else
	return null;
public static Point3d? SelectPointInMidDocument(System.Windows.Window modalUi)
	var dwg=Application.DocumentManager.MdiActiveDocument;
	var ed=dwg.Editor;
	using (ed.StartUserInteraction(modalUi)
		return SelectPointInMdiDocument(ed);
public static Point3d? SelectPointInMidDocument(Form modalUi)
	var ed=dwg.Editor;
Then, in your modal dialog's code behind, you can do:
private void Button_Click(...)
        // the form's code really does not need to know
        // when/how to hide the form and get user input from Editor
	var selectedPt=TheUtilityClass.SelectPointInMdiDocument(this);
	if (selectedPt.HasValue)
		// Show the point coordinate on the modal UI
HTH
Norman Yuan
Drive CAD With Code
Message 7 of 11
s_velasquez
Thanks for the answer Norman,
See the tests I did in my project trabalhando com o AutoCAD 2025:
1 - 'SelectPointInMdiDocument' I changed the argument 'this' to 'ed' and it worked without problems.
2- the methods 'SelectPointInMidDocument(System.Windows.Window modalUi)' and 'SelectPointInMidDocument(Form modalUi)' showed the error below:
"Exception thrown: 'System.ArgumentException' in accoremgd.dll
An exception of type 'System.ArgumentException' occurred in accoremgd.dll but was not handled in user code
Window is not active:"
Please tell me where my mistake is
     var doc = AcAp.DocumentManager.MdiActiveDocument;
     var ed = doc.Editor;
     var modalUi = new WpfModalForm();
     var selectedPt = JigManager.TheUtilityClass.SelectPointInMidDocument(modalUi);
     NameBox.Text = selectedPt.ToString();
Message 8 of 11
norman.yuan
What is this? Why do not need to create an instance of WPF window and pass it to SelectPointInMidDocument()?
I assume the "Ok" button that is clicked is on a modal UI (WPF, or Win Form), which should be the one being passed to SelectPointInMidDocument() method, that is:
var selectedPt = JigManager.TheUtilityClass.SelectPointInMidDocument(this);
By the way, the error you get is because you pass in a non-displayed, non-modal window to the StartUserInteraction()!
Norman Yuan
Drive CAD With Code
Message 9 of 11
s_velasquez
Hi Norman,
You are right,
That is my mistake.
I am calling your method in a static class so it does not work. I have 13 WPF windows in my project and I thought about using a single function to handle the insertion of blocks using.
The 'Block Insertion' class handles the insertion of blocks using 'Jig'
private void GetPointButton_Click(object sender, RoutedEventArgs e)
	// Calling a static class
    BlockInsertion.Insert("BlockTest");
//My static class
public static class BlockInsertion
    public static void Insert(string blockName)
        var db = doc.Database;
        // Collect insertion point here
        var selectedPt = JigManager.TheUtilityClass.SelectPointInMdiDocument(WpfModalForm);
            ed.WriteMessage("/nslectedPT: " + selectedPt.ToString());
Message 10 of 11
norman.yuan
What is WpfModalForm? Where is it declared and the modal form is instantiated and displayed? If it is indeed a modal form that is shown as modal form, how can your code reaches it in a static class/method without passing it in as a parameter? It looks to me, the code is not well structured even you managed to compile it.
Also, the JigManager used inside implies that AFTER selecting a point, the block would be inserted in the "Jig" style, which means the user would continue to interacting with the Editor. So, it does not make sense to only call Editor.StartUserInteraction() inside the SelectPointInMdiDocument() method - you should hide the modal form in the whole process of block insertion.
So, since you want the block insertion is done in a re-usable static method, meaning, it could be called from, or not from a modal UI. Obviously, when called from modal UI, you want to hide the UI first and show it back after. The simplest way is the same as I showed in previous reply: just add another OVERLOAD Insert() method that take either Win Form, or WPF Window as input:
    BlockInsertion.Insert("BlockTest", this);
//My static class
        var selectedPt = JigManager.TheUtilityClass.SelectPointInMdiDocument();
	public static void Insert(string blockName, System.Windows.Window modalWindow)
        using (ed.StartUserInteraction(modalWindow)
			Insert(blockName);
In this case, you want to relabel/rename the button on the form from "Point >" to "Insert >" and from "GetPointButton" to "InsertBlockButton", not because you have to, but for code's easy readability😅
Norman Yuan
Drive CAD With Code
Message 11 of 11
s_velasquez
Thank you very much Norman, Your code worked perfectly, I have a lot to learn from it.
