Listbox removeAt - Datasource error
k005
Advisor Advisor
Message 1 of 11
k005
Hi all !
I am listing some text files from my dwg file in Listbox.
I want to do extraction with the code below. But it gives an error about datasource.
error :
"Items collection cannot be modified when the DataSource property is set."
How can I remove an item from the listbox without this error?
int secim = listBox1.SelectedIndex;
            if (secim != -1)
                listBox1.Items.RemoveAt(secim);
               // listBox1.DataSource = listBox1.Items;
            else
                MessageBox.Show("Seçim Yapın!");
Replies (10)
Message 2 of 11
fieldguy
this has nothing to do with autocad .net.  you've been told several times - try google
Message 3 of 11
k005
dwg file... that's why I wrote it here. normally you don't have any questions.
Message 4 of 11
Norman_Yuan
I strongly concur with @fieldguy's reply: this forum is for AutoCAD .NET API discussion. While more generic/basic programming topics could also discussed, one can get suitable answers a lot easier/quicker. For example, simply enter "Items collection cannot be modified when the DataSource property is set" in Google search, you would get over 100,000 results, and the very first one would give you the CLEAREST, SIMPLEST answer, with sample code. Please try it before post back again.
Norman Yuan
Drive CAD With Code
Message 5 of 11
fieldguy
your subject is "listbox removeat - datasource error".  it doesn't matter what's in the listbox.  Enter those exact words in google for more than 1 million hits.  "Listbox" is not a member of the autocad API.
IMO you are looking for someone else to do your work for you.
Message 6 of 11
k005
You think I didn't google this?
You offer suggestions but not solutions...
Now what is the result: You wrote 0 answers in vain.
Message 7 of 11
k005
I totally disagree with this guy...@ fieldguy
Message 8 of 11
hippe013
@k005
I am going to have to agree with everyone else that has responded to your question. The solution to your problem is in the error message that you posted.
It clearly stats that an Items Collection (the list in your listbox) cannot be modified when the DataSource property is set.
Your solution is the following: Add items to your listbox manually rather than using the DataSource property.
Ultimately, I have found that the people on this forum are always more than willing to help with AutoCAD API related questions and are often excited to do so. They are NOT, however, here to provide answers to other API related questions or to do the work for someone else.
With that said, I hope that this helps you to find a solution to your error.
Message 9 of 11
k005
@hippe013
i tried adding it manually listbox is getting empty... the code should change completely.
I want to do this while in datasource ? Isn't there a method for this?
Message 10 of 11
hippe013
There are many ways to skin a cat. Without going on too much about MVVM, databinding, and the whole works... a quick example is the following:
The following code works, but probably not ideal.
'In the Context of the ListBox (Manually Add)
ListBox1.Items.Add("Item 1")
ListBox1.Items.Add("Item 2")
ListBox1.Items.Add("Item 3")
'In the context of a method:
Dim idx As Integer = ListBox1.SelectedIndex
ListBox1.Items.RemoveAt(idx)
The following code also works, better than the previous, but could also be improved upon.
'In the Context of the ListBox (set ItemsSource)
Private obList As New ObservableCollection(Of String)(New List(Of String) From {"Item 1", "Item 2", "Item 3"})
ListBox1.ItemsSource = obList
Dim idx as Integer = ListBox1.SelectedIndex
obList.RemoveAt(idx)
I hope that this clarifies for you what I meant about adding the items manually. You are setting the ListBox1.ItemSource to a list of items and then when you go to remove an item you are removing from ListBox1.Items and this is causing your error.
Message 11 of 11
k005
OK. Thanks.
