LispFunction Runs Twice
Christopher.Fugitt
Christopher.Fugitt
I have a LispFunction that does some work to get data from a drawing and saves it to a temporary file. When the LispFunction is run the first time it runs twice, every other time after it runs twice. Is this a known issue or is there maybe a setting that is causing this. Adding Lisp before the LispFunction doesn't appear to affect it running twice.
This is Civil 3D 2020.6 Update.
Christopher.Fugitt
It was a defect in my code. I was writing to the XML file in the creation of the object and I suspect .NET is running the initialization of the class in order to create the XML file which caused the issue.
JamesMaeding
@Christopher.Fugitt
Write a bunch more of these where you solve your own post! Get that 6 rating up LOL.
I remember once I was an 11 for one day. Then they recognized my name....
internal protected virtual unsafe Human() : mostlyHarmless
I'm just here for the Shelties
Civil3DReminders
Well, this account has a bit more forum cred. I'm not quite sure why I have so many Autodesk accounts.
