LINQ to get all objects with extension dictionary
js75CAD
js75CAD
I am hoping someone can help me with what I can only assume is something easy but stumps me:
I have add an xrecord to the extension data of several entities. In this instance Polylines. The record name is "MyData".
All I want to do is get all of these items using LINQ if possible. I am sure I have seen it done in an example skipped over long ago, but not sure.
Using tr As Transaction = db.TransactionManager.StartTransaction()
Dim bt As BlockTable = tr.GetObject(db.BlockTableId, OpenMode.ForWrite)
Dim acBlkTblRec As BlockTableRecord = tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite)
Dim b As IEnumerable(Of ObjectId) = acBlkTblRec.Cast(Of ObjectId)()
' This works!, but i still have to iterate to find the record name
Dim testRes1 As List(Of ObjectId) = (From id In b
                                     Where Not (CType(tr.GetObject(id, OpenMode.ForRead), ntity).ExtensionDictionary.IsNull)
                                     Select id).ToList
' There must be a way to convert this into the extension dictionary and then see if the xRecord name exists??
                                     Where Not (CType(tr.GetObject(id, OpenMode.ForRead), Entity).ExtensionDictionary.IsNull)
                                     Select xRec Where( TryCast(tr.GetObject(id, OpenMode.ForRead), ExtensionDictionary).Contains("MyData").ToList
End using
How do I create the DBDictionary I need to use it in the LINQ function??
_gile
Here's a way using an anonymous type written in "method syntax".
        static Dictionary<ObjectId, ResultBuffer> GetMyXrecordData(Database db)
            using (var tr = db.TransactionManager.StartTransaction())
                return
                    ((BlockTableRecord)tr.GetObject(SymbolUtilityServices.GetBlockModelSpaceId(db), OpenMode.ForRead))
                    .Cast<ObjectId>()
                    .Select(id => (Entity)tr.GetObject(id, OpenMode.ForRead))
                    .Where(entity => !entity.ExtensionDictionary.IsNull)
                    .Select(entity => new
                        entity.ObjectId,
                        XDictionary = (DBDictionary)tr.GetObject(entity.ExtensionDictionary, OpenMode.ForRead)
                    .Where(pair => pair.XDictionary.Contains("MyData"))
                    .ToDictionary(
                        pair => pair.ObjectId,
                        pair => ((Xrecord)tr.GetObject(pair.XDictionary.GetAt("MyData"), OpenMode.ForRead)).Data);
Gilles Chanteau
Programmation AutoCAD LISP/.NET
GileCAD
GitHub
_gile
Oops!... I read the request to fast. Here's a reply which is closer to your needs.
    var testRes1 =
        .Cast<ObjectId>()
        .Where(entity => ((DBDictionary)tr.GetObject(entity.ExtensionDictionary, OpenMode.ForRead)).Contains("MyData"))
        .Select(entity => entity.ObjectId)
        .ToList();
Gilles Chanteau
GileCAD
GitHub
js75CAD
Mate.... what can I say. I hope you are somewhere in this world knowing I am raising a cold beer to you tonight!
Thank you _gile. I was trying to cast the entity in my attempt and just could not get the sequence right.
You sir are a gentleman.
