Linking a Ribbon Button to a .Net Command
JamesLH88
Message 1 of 23
JamesLH88
Hi All,
I wonder if anybody can help me.
I have a few commands that I have created, and they work great if called via the command line.
[CommandMethod("MyCommand", CommandFlags.UsePickSet | CommandFlags.Redraw | CommandFlags.Modal)]
public void MyCommandFunction()
       // MY CODE IS HERE
I have also created a new ribbon tab, with panel, and RibbonButton, and assigned a CommandHandler which calls a Action (callback function). However, I can't seem to get my button to trigger 'MyCommand'.
RibbonCommandHandler ActionHandler = new RibbonCommandHandler();
ActionHandler.CallBack = CallBackFunction;
myButton.Id = "MyButtonID";
myButton.CommandHandler = ActionHandler;
public class RibbonCommandHandler : System.Windows.Input.ICommand
    public Action<String> CallBack;
    public event EventHandler CanExecuteChanged;
    public bool CanExecute(object parameter)
        return true;
    public void Execute(object parameter)
        if (parameter is RibbonButton)
            RibbonButton button = parameter as RibbonButton;
            CallBack(button.Id);
public void CallBackFunction(String message)
    Document doc = Application.DocumentManager.MdiActiveDocument;
    switch (message)
        case "MyButtonID":
            // I AM STUCK HERE .....
            break;
Apologies if I have failed to explain my problem very clearly. I am not sure if I am even going around the issue the right way. But any assistance to point me in the right direction would be greatly appreciated!
James
Replies (22)
Message 21 of 23
TiStars
Hi, sorry for disturbing you again, I wonder if you know any docs about making installer for AutoCAD? is it same with making a normal installer of window software like setup.exe etc? Thank you very much
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
您的问题是否已得到解答?请点击“接受解答”按钮。
Message 22 of 23
ActivistInvestor
You can see > this document <
Message 23 of 23
TiStars
Many many thanks!!!
天涯海角的山姆
您认为此帖子是否有用?欢迎为此帖点赞。
