Jigging - Inserting Block Issues (not snapping to all points?)
Message 1 of 1
Alright I have an issue and not sure how to even show this...  Or even if its possible without the block files (can't post them, company rules).
I got a ribbon bar that has many blocks, now when inserting them into the drawing, yeah I can do that.  Select a point, rotate, thats all good.  Though not all my blocks that I place will allow the snap functions to work on them?  Some have no snap functions to existing blocks I placed, some will only select the base point that I inserted said block, and some will allow all the snap functions to work with placing them on mid points, corners, etc.
Is this a code function or an autocad setting I would need to change, really comes down to the question.  Tool Pallet and a custom CUI that I does the same function in autocad works flawlessly, and I just didn't notice it til recently.
Here is the code segments related to the jigging of the blocks.
Block Jig
Imports Autodesk.AutoCAD.DatabaseServices
Imports Autodesk.AutoCAD.Geometry
Imports Autodesk.AutoCAD.EditorInput
Imports Autodesk.AutoCAD.ApplicationServices
Namespace Insert
    Public Class InsertBlockJig
        Public Class InsertJig
            Inherits EntityJig
            Private vJigPromptCounter As Integer
            Private vRotationAngleUse As Boolean = False
            Private vRotationAngleValue As Double = 0.0
            ' private double objPrevAngle;
            ' private double objCurAngle;
            Private vScaleValue As Double = 1.0
            Public Sub New(ByVal BlockId As ObjectId, ByVal Position__1 As Point3d, ByVal Normal As Vector3d)
                MyBase.New(New BlockReference(Position__1, BlockId))
                BlockReference.Normal = Normal
                position = Position__1
            End Sub
            Private mCenterPt As Point3d, mActualPoint As Point3d
            Public Sub New(ByVal br As BlockReference)
                MyBase.New(br)
                mCenterPt = br.Position
            End Sub
            Protected Overrides Function Sampler(ByVal prompts As JigPrompts) As SamplerStatus
                If vJigPromptCounter = 0 Then
                    ' Maybe let the scale (and/or rotation) be changed with a option on the command-line
                    Me.BlockReference.ScaleFactors = New Scale3d(vScaleValue, vScaleValue, vScaleValue)
                    ' And eval rotation here...
                    If vRotationAngleUse Then
                        Me.BlockReference.Rotation = vRotationAngleValue
                    ' Maybe still check the counter no (1) if the rotation was  set...
                    Dim jigOpts As New JigPromptPointOptions()
                    jigOpts.UserInputControls = UserInputControls.NoZeroResponseAccepted &
                        UserInputControls.NullResponseAccepted &
                        UserInputControls.Accept3dCoordinates
                    jigOpts.Message = vbLf & "Insertion point: "
                    Dim res As PromptPointResult = prompts.AcquirePoint(jigOpts)
                    'Point3d BlkRefPoint = BlockReference.Position;
                    Dim curPoint As Point3d = res.Value
                    If position.DistanceTo(curPoint) > 0.0001 Then
                        ' 1.0e-4 make it 10 units (depending on drawing...)
                        'if (this.BlockReference.Position != curPoint)  // 1.0e-4 make it 10 units (depending on drawing...)
                        position = curPoint
                    Else
                        Return SamplerStatus.NoChange
                    If res.Status = PromptStatus.Cancel Then
                        Return SamplerStatus.Cancel
                        jigOpts.Message = vbLf & "Block Insertion Canceled"
                    Else
                        Return SamplerStatus.OK
                Else
                    If vJigPromptCounter = 1 Then
                        ' Activate Rotate Jig...Just check if there already was a rotation...??
                        ' JigPromptAngleOptions
                        Dim jigOpts As New JigPromptAngleOptions()
                        jigOpts.BasePoint = Me.BlockReference.Position
                        jigOpts.DefaultValue = 0
                        jigOpts.Message = "Get angle: "
                        jigOpts.UseBasePoint = True
                        jigOpts.UserInputControls = UserInputControls.Accept3dCoordinates
                        'jigOpts.UserInputControls = UserInputControls.NoZeroResponseAccepted &
                        '    UserInputControls.NullResponseAccepted &
                        '    UserInputControls.Accept3dCoordinates
                        Dim res As PromptDoubleResult = prompts.AcquireAngle(jigOpts)
                        Dim curAngle As Double = res.Value
                        If Me.BlockReference.Rotation <> curAngle Then
                            blockRotation = curAngle
                        Else
                        Else
                    Else
                        ' Just in case...
            End Function
            Protected Overrides Function Update() As Boolean
                Try
                    Dim returnvalue As Boolean = False
                    Select Case vJigPromptCounter
                        Case 0
                            ' Insert point Update...
                            ' this.BlockReference.Position = position;
                            ' return true;
                            If Me.BlockReference.Position.DistanceTo(position) > 0.0001 Then
                                ' Idem aan boven depending on drawing scale..
                                ' Maybe the distance can be less..if solved?
                                Me.BlockReference.Position = position
                                returnvalue = True
                            Exit Select
                        Case 1
                            ' Rotate Update...
                            If Me.BlockReference.Rotation <> blockRotation Then
                                Me.BlockReference.Rotation = blockRotation
                                returnvalue = True
                            Exit Select
                    End Select
                    Return returnvalue
                Catch generatedExceptionName As System.Exception
                End Try
                Return False
                ' Why Why Why..
            End Function
            Public Property RotationAngleUse() As Boolean
                Get
                    Return vRotationAngleUse
                End Get
                Set(ByVal value As Boolean)
                    vRotationAngleUse = value
                End Set
            End Property
            Public Property RotationAngleValue() As Double
                Get
                    Return vRotationAngleValue
                End Get
                Set(ByVal value As Double)
                    vRotationAngleValue = value
                End Set
            End Property
            Public Property ScaleValue() As Double
                Get
                    Return vScaleValue
                End Get
                    If value <> 0 Then
                        vScaleValue = value
                End Set
            End Property
            Public Property JigPromptCounter() As Integer
                Get
                    Return vJigPromptCounter
                End Get
                Set(ByVal value As Integer)
                    vJigPromptCounter = value
                End Set
            End Property
            Public ReadOnly Property BlockReference() As BlockReference
                Get
                    Return TryCast(MyBase.Entity, BlockReference)
                End Get
            End Property
            Private position As Point3d
            Private blockRotation As Double
        End Class
        ' Test InsertJig from command line
        Private vRotationVal As Double = 0.0
        Private vRotationUse As Boolean = True
        Private vScaleVal As Double = 1.0
            Get
                Return vRotationUse
            End Get
                vRotationUse = value
            End Set
        End Property
            Get
                Return vRotationVal
            End Get
                vRotationVal = value
            End Set
        End Property
            Get
                Return vScaleVal
            End Get
                If value <> 0 Then
                    vScaleVal = value
            End Set
        End Property
        ' AcadApp.DocumentManager.MdiActiveDocument.Editor
        ' [CommandMethod("DragInsertDemo")] static
        Public Sub StartInsert(ByVal JigBlockName As [String])
            Dim ed As Editor = Application.DocumentManager.MdiActiveDocument.Editor
            Dim db As Database = HostApplicationServices.WorkingDatabase
            ' Application.DocumentManager.MdiActiveDocument.Database;
            Dim Normal As Vector3d = db.Ucsxdir.CrossProduct(db.Ucsydir)
            ' Editor ed = Application.DocumentManager.MdiActiveDocument.Editor;
            ' PromptStringOptions opts = new PromptStringOptions("\nBlock name: ");
            ' opts.AllowSpaces = true;
            ' using( DocumentLock docLock = ed.Document.LockDocument() ) // Maybe Move this at first..??
            Dim res As PromptResult
            ' = ed.GetString(opts);
            If JigBlockName <> String.Empty Then
                Dim block As ObjectId = GetBlockId(db, JigBlockName)
                If block.IsNull Then
                    ed.WriteMessage(vbLf & "Block {0} not found.", JigBlockName)
                    Return
                Dim jig As New InsertJig(block, Point3d.Origin, Normal.GetNormal())
                If vRotationUse = True Then
                    jig.RotationAngleUse = True
                    jig.RotationAngleValue = vRotationVal
                Else
                    jig.RotationAngleUse = False
                jig.ScaleValue = vScaleVal
                jig.JigPromptCounter = 0
                ' Start with insertpoint
                Using docLock As DocumentLock = Application.DocumentManager.MdiActiveDocument.LockDocument()
                    res = ed.Drag(jig)
                    ' First Jig option..[Insertpoint]
                    ' Should it accept a rightclick as the 0-point of the drawing?
                    ' or does that cancel the operation...?
                    If res.Status = PromptStatus.OK Then
                        ' Here also the Rotation-Jig should Start...
                        ' if Rotation was fixed this should have been set at first...
                        ' Should Accept rightclick as 0-rotation
                        ' Ready...end the Jig
                        Else
                            ' Start a new Jig for the rotation..
                            jig.JigPromptCounter = 1
                            res = ed.Drag(jig)
                        ' if jig.RotationAngleUse = false then do it...
                        ' jig.RotationAngleValue = 1; // Or skip this al together if it's a given rotation...
                        ' No checking to be done by Jig(ger)..??
                        Dim tm As Autodesk.AutoCAD.DatabaseServices.TransactionManager = db.TransactionManager
                            ' Second check needed if there was a rotation Jig..
                            Using tr As Transaction = tm.StartTransaction()
                                Dim bt As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead, False), BlockTable)
                                ' Do Check in what space You are!!!
                                ' It could be a Layout...
                                Dim btr As BlockTableRecord = DirectCast(tr.GetObject(bt(BlockTableRecord.ModelSpace), OpenMode.ForWrite, False), BlockTableRecord)
                                btr.AppendEntity(jig.BlockReference)
                                tr.AddNewlyCreatedDBObject(jig.BlockReference, True)
                                tr.Commit()
                            End Using
                End Using
        End Sub
        Private Shared Function GetBlockId(ByVal db As Database, ByVal Name As String) As ObjectId
            Dim id As ObjectId = ObjectId.Null
            Using tr As Transaction = db.TransactionManager.StartTransaction()
                Dim blocks As BlockTable = DirectCast(tr.GetObject(db.BlockTableId, OpenMode.ForRead), BlockTable)
                If blocks.Has(Name) Then
                    id = blocks(Name)
                    If id.IsErased Then
                        For Each btrId As ObjectId In blocks
                            If Not id.IsErased Then
                                Dim rec As BlockTableRecord = DirectCast(tr.GetObject(btrId, OpenMode.ForRead), BlockTableRecord)
                                If String.Compare(rec.Name, Name, True) = 0 Then
                                    id = btrId
                                    Exit For
                        Next
                tr.Commit()
            End Using
            Return id
        End Function
    End Class
End Namespace
Drawing
Namespace Insert
    Public Class InsertDrawing
        Public DrawingPath As [String] = ""
        Public BlockName As [String] = ""
        Public Sub InsertIntoAutoCAD()
            ' Insert the block into the AutoCAD model
            Try
                Dim doc As Document = Application.DocumentManager.MdiActiveDocument
                Dim fname As [String] = DrawingPath
                    Using db As New Database(False, False)
                        'read block drawing do we need Lockdocument..?? Not Always..?
                        db.ReadDwgFile(fname, System.IO.FileShare.Read, True, Nothing)
                        Using t As Transaction = doc.TransactionManager.StartTransaction()
                            Dim idBTR As ObjectId = doc.Database.Insert(BlockName, db, False)
                            t.Commit()
                        End Using
                    End Using
                End Using
            Catch e As System.Exception
                ' Console.WriteLine("{0} Exception caught.", e);
                ed.WriteMessage(vbLf & "Error {0} DrawingInsert", e)
            End Try
        End Sub
    End Class
End Namespace
Commands
Imports Autodesk.AutoCAD.Runtime
<Assembly: CommandClass(GetType(Insert.Commands))>
Namespace Insert
    Public Class Commands
        <CommandMethod("InsertBottleConveyor")> _
        Public Sub InsertConveyor()
            Dim InsClass As New InsertDrawing()
            InsClass.BlockName = ConveyorRibbonBar.BlockName
            InsClass.DrawingPath = "C:\Temp\" & ConveyorRibbonBar.BlockName & ".dwg"
            InsClass.InsertIntoAutoCAD()
            InsClass = Nothing
            Dim BlkClass As New InsertBlockJig()
            BlkClass.RotationAngleUse = False
            BlkClass.StartInsert(ConveyorRibbonBar.BlockName)
            BlkClass = Nothing
        End Sub
    End Class
End Namespace
Again selecting the proper snap points I have sometimes it works flawlessly, others its only on node points and sometimes nothing of an existing block in the drawing.  Oh another note, even sometimes snap points will work with a block just put down but not with any other blocks of the same name.
Replies (0)
