Jig functionality when invoked from Palette
I implemented some code from the TTI blog to create polylines with a Jig. (http://through-the-interface.typepad.com/through_the_interface/2006/11/controlling_int_1.html)
It is basically a Jig with a line that is drawn to mimic the PLINE functionality.
When doing this from a command, all is good.
When doing this from a button on a palette, the line drawn by the Jig is not visible, nor are snaps.
I also noticed that when running from a command, the comboboxes in the toolbars lock up, but this does not happen from the palette.
Any thoughts? I'm using AutoCAD 2007 for this project.
http://cupocadnet.blogspot.com Edited by: bert.vanpeteghem@dolmen.be on Oct 5, 2009 1:54 PM
Rather than run your code directly from a control event on your palette,
define an AutoCAD command dynamically using the undocumented AddCommand()
method from Autodesk.AutoCAD.Internal.Utils. From the control event handler
on your pallete, invoke the command using SendStringToExecute().
Here's a quick example:
{code}
using System;
using System.Collections.Generic;
using System.Linq;
using System.Text;
using System.Windows.Forms;
using Autodesk.AutoCAD.Runtime;
using Autodesk.AutoCAD.ApplicationServices;
using Acad = Autodesk.AutoCAD.ApplicationServices.Application;
using System.Drawing;
namespace Namespace1
public class MyPaletteControl : UserControl
// A button that when clicked, triggers the
// code in the modal command handler to run:
private Button button1 = new Button();
// constructor
public MyPaletteControl()
this.Controls.Add( button1 );
button1.Location = new Point( 10, 10 );
button1.Visible = true;
button1.Click += new EventHandler( button1_Click );
// Add a command that runs when button1 is clicked:
Autodesk.AutoCAD.Internal.Utils.AddCommand(
"MYPALETTECONTROL",
"MYPALETTECOMMAND1",
CommandFlags.NoActionRecording
| CommandFlags.NoHistory
| CommandFlags.NoMultiple,
this.OnMyPalettteCommand1 );
void button1_Click( object sender, EventArgs e )
Document doc = Acad.DocumentManager.MdiActiveDocument;
if( doc != null && doc.Editor.IsQuiescent )
doc.SendStringToExecute( "MYPALETTECOMMAND1\n",
true, false, false );
private void OnMyPalettteCommand1()
// disable the palette control to avoid unintended
// reentry while the command is in progress.
this.Enabled = false;
// TODO:
// code here behaves like it is being run
// from a modal command method (because it is)
// reenable the control:
this.Enabled = true;
{code}
http://www.caddzone.com
AcadXTabs: MDI Document Tabs for AutoCAD
Supporting AutoCAD 2000 through 2010
http://www.acadxtabs.com
Email: string.Format("{0}@{1}.com", "tonyt", "caddzone");
wrote in message
news:6265716@discussion.autodesk.com...
functionality.
Very very nice, thanks !
oops... wait a minute...
There's one small problem with that example, which is that it leaves the
command defined, which means the user could issue it, which is something you
can't allow.
Here's a slightly different version that adds the command just before it
runs, and removes it when it completes.
{code}
using System;
using System.Linq;
using System.Text;
// Add the temporary command and then execute it:
"MYPALETTECONTROL",
this.OnMyPaletteCommand1 );
private void OnMyPaletteCommand1()
try
button1.Enabled = false;
// TODO:
finally
// remove the command that triggered the call to
// this method, so the user can't issue it directly:
Autodesk.AutoCAD.Internal.Utils.RemoveCommand(
"MYPALETTECONTROL", "MYPALETTECOMMAND1" );
// reenable the button:
button1.Enabled = true;
{code}
"Tony Tanzillo" wrote in message
news:6265911@discussion.autodesk.com...
{code}
using System;
using System.Linq;
using System.Text;
// constructor
"MYPALETTECONTROL",
// TODO:
{code}
wrote in message
functionality.
Hmm, it seams this method does not yet exist in 2007, any idea on how to do this in AutoCAD 2007?
No can do in 2007. The method it uses didn't appear until AutoCAD 2009.
There's no other simple way of doing that in 2007 I'm afraid.
wrote in message
news:6267453@discussion.autodesk.com...
I found a way 🙂
With delegates and SendStringToExecute, I managed to get this working. I will post the details later today.
Update: I posted the details on my blog: http://cupocadnet.blogspot.com/2009/10/using-jigs-from-palettes.html
http://cupocadnet.blogspot.com Edited by: bert.vanpeteghem@dolmen.be on Oct 12, 2009 8:20 AM
