Jig a block with keywords
Paulio
Paulio
I'm using the code from Kean's blog here to jig insert a block. What it's missing is the ability to change the rotation and base point during the jig.
I'm basically trying to reproduce the functionality that the normal Insert command gives which, I know, sounds a bit like I'm reinventing the wheel but I need to use the jig as I want to do other stuff to the block after the insert has finished like exploding it or changing its layer.
I've tried Tony T's commandline but that doesn't seem to work with commands that require user interaction.
I've got as far handling the keywords e.g. if the user enters "R" to rotate, I can ask them to enter an angle using ed.GetAngle but then if I call Run on the jig again (to continue the jig), the point that the block is inserted at is different to where the user clicked to place it. Calling Run again here might not be the right thing to do...
Also, I can't see how to temporarily add the block to the drawing so that the user can select a new base point by entering B.
All pointers gratefully received.
Balaji_Ram
Hi Paulio,
Have you seen the latest post (posted today Smiley Happy) on Kean's blog ?
http://through-the-interface.typepad.com/through_the_interface/2012/08/a-handy-jig-for-creating-auto...
Sorry, I did not understand the need for you to call the "Run" method again. Are you not getting the inputs along with the keywords in the "Sampler" method ? Kean's blog post does the same.
If this does not help, can you please explain the kind of behavior that you are trying to achieve ?
A buildable sample project demonstrating the issue will also be helpful.
Balaji
Developer Technical Services
Autodesk Developer Network
