Issue in filter selection
mehdi-guida
mehdi-guida
Hi
I have below codes. But it has error(image attached).
If i omit the line 'filterlist[1] = new TypedValue(67, s);' it works.
What is the issue?
Thank you
 Editor editor = Autodesk.AutoCAD.ApplicationServices.Application.DocumentManager.MdiActiveDocument.Editor;
LayoutManager layoutMgr = LayoutManager.Current;
string s = layoutMgr.CurrentLayout;
TypedValue[] filterlist = new TypedValue[2];
filterlist[0] = new TypedValue(2, "note");
Autodesk.AutoCAD.EditorInput.SelectionFilter filter = new Autodesk.AutoCAD.EditorInput.SelectionFilter(filterlist);
PromptSelectionResult Promptentity = editor.SelectAll(filter);
SelectionSet sval = Promptentity.Value; 
_gile
Try this way:
var filter = new SelectionFilter(new[]
    new TypedValue(2, "note"),
    new TypedValue(410, LayoutManager.Current.CurrentLayout)
Gilles Chanteau
GileCAD
GitHub
mehdi-guida
Thank you
But it works only for simple blocks.
if the blocks are dynamic , it can't select them.
_gile
You cannot directly filter dynamic blocs by name wit a selection filter. You have to check the Name of the DynamicBlockTableRecord of each block reference.
Assuming you want to get all blocks by name in the current layout BlockTableRecord, the simplest (and faster) way is to iterate through all entities in the current space.
Here's an example:
using (var tr = db.TransactionManager.StartTransaction())
    var curSpace = (BlockTableRecord)tr.GetObject(db.CurrentSpaceId, OpenMode.ForRead);
    foreach (ObjectId id in curSpace)
        if (id.ObjectClass.DxfName == "INSERT")
            var br = (BlockReference)tr.GetObject(id, OpenMode.ForRead);
            var btr = (BlockTableRecord)tr.GetObject(br.DynamicBlockTableRecord, OpenMode.ForRead);
            if (btr.Name == "note")
                // do your stuff with the block reference
    tr.Commit();
Another example with a separate method using Linq
static IEnumerable<ObjectId> GetAllCurrentSpaceBlocksByName(string blockName)
    var db = HostApplicationServices.WorkingDatabase;
    using (var tr = db.TransactionManager.StartOpenCloseTransaction())
        return curSpace
            .Cast<ObjectId>()
            .Where(id => id.ObjectClass.DxfName == "INSERT")
            .Select(id => (BlockReference)tr.GetObject(id, OpenMode.ForRead))
            .Where(br => ((BlockTableRecord)tr.GetObject(br.DynamicBlockTableRecord, OpenMode.ForRead)).Name == blockName)
            .Select(br => br.ObjectId);
Gilles Chanteau
GileCAD
GitHub
