Is there a way to get drawing size without opening the actual DWG file?
kdongLVTHZ
kdongLVTHZ
I was able to get drawing size by opening the DWG file like this:
Document doc = CadApp.DocumentManager.Open(dwgfile, false);
But this code triggers opening the dwg in AutoCAD, which I want to avoid. Is there a way to get this 'doc' handle without explicitly open the dwgfile in AutoCAD as shown above?
Thanks!
KD
ActivistInvestor
Aside from not knowing exactly what you mean by 'drawing size', you can use the Database.ReadDwgFile() method to access a drawing file without opening it in the editor. It returns an instance of a Database object that you must dispose when you are finished using it.
